  ENOVIA VPLM
  ENOVIAVPM V1.6 & V5R16 Interoperability Support
Autor Thema:  ENOVIAVPM V1.6 & V5R16 Interoperability Support (1212 mal gelesen)
Axel.Strasser
Selbstständig im Bereich PLM/CAx
Sehen Sie sich das Profil von Axel.Strasser an!   Senden Sie eine Private Message an Axel.Strasser  Schreiben Sie einen Gästebucheintrag für Axel.Strasser
Früher war vieles gut, und das wäre es heute immer noch, wenn man die Finger davon gelassen hätte!
erstellt am: 18. Mai. 2007 14:56    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
The following combinations were announced as supported:
  -ENOVIAvpm 1.5 with V5R16
  -ENOVIAvpm 1.6 with V5R17
In order to meet some customers' requirements, we are announcing support of
ENOVIAvpm 1.6 interoperability with V5R16.
Customers requiring support for this configuration must:
  -explicitly request it through your IBM sales team,
  -provide a detailed migration plan showing a detailed plan and date when
    ENOVIAVPM V1.6 will be running with a V5 release higher than R16,
  -be in production with V5R16, and
  -submit your request for support of this configuration by 2 June 2007.
Only customers meeting these requirements will receive support for this
configuration; there is no additional charge for this support.
Remember that the PLM Technical Support web site always contains the end of
support dates for all current PLM products/releases: click on
"Product Life Cycle  -> End of support dates" near the bottom of its top page.
*  PLEASE DO NOT RESPOND TO THIS NOTE (sent by an unattended service machine)!
*  If you have comments or questions about this flash, or
*    -if you do not wish to receive future informational flashes, or
*    -if you no longer need access to the IBM PLM Technical Support web site,
*  use the following link to access our FEEDBACK form and contact us directly:
*      http://www.ibm.com/software/applications/plm/support/feedback.wss
