Original erstellt von rosomapa:
soll anscheinend ab NX8.5 möglich sein.
Mein Call bei Siemens wurde auch soeben mit der gleichen Begründung geschlossen
und dass die vorigen Versionen dies leider nicht unterstützen.
Hierzu der Originalauszug aus der NX 8.5 Dokumentation (Teamcenter Integration for NX-> Basic creation and management of data-> Creating a new item-> Asynchronous batch creation of JT files):
To enable asynchronous batch creation of JT files:
1.Choose File-> Utilities-> Customer Defaults-> Gateway-> JT Files.
2.Select the Teamcenter Integration tab. Clear Synchronous JT Creation in File Save (selected by default).
3.Select the Export tab. Select Save JT Data.
4.In the Teamcenter %Dispatcher_Root% directory, open the translator.xml file from the Module\conf directory.
5.Set the isactive attribute to true to activate the nxtransdirect translator:
<NxTransDirect provider="SIEMENS" service="nxtransdirect" isactive="true" OutputNeeded="false">
6.In the Teamcenter %Dispatcher_Root% directory, open the nxtransdirect.bat file from the Module\Translators\nxtransdirect directory.
7.Edit the values for TC_ROOT, TC_DATA, UGII_BASE_DIR, UGS_LICENSE_SERVER to the appropriate values based on the installation at your site.
8.(Optional). Remove the need for translation to be done by a Teamcenter module user.
By default, the translator uses autologin so the user running the translator module must be a Teamcenter user with the appropriate privileges to translate; therefore, the translation is performed by the Teamcenter module user. You can change this to
enable the nxtransdirect translator to login as though it was the user that initiated the translation (the user that saved the data in NX).
a.In the Teamcenter %Dispatcher_Root% directory, open the translator.xml file from the Module\conf directory.
b.Set the autologin option to false:
<Option name="clientoption" optionkey="use_module_user" string="-autologin" value="false" description="Specifies whether to auto login as module user."/>
For additional information on using the Dispatcher and nxtransdirect translator, see the Teamcenter documentation.
MfG Michael
