| | | Gut zu wissen: Hilfreiche Tipps und Tricks aus der Praxis prägnant, und auf den Punkt gebracht für Autodesk Produkte |
Thema: Hohe CPU-Last durch Registry-Abfragen (1702 / mal gelesen)
Peter2 Ehrenmitglied V.I.P. h.c.
Beiträge: 3701 Registriert: 15.10.2003 Win 10/64 Pro AutoCAD MAP 3D 2018 / 2023 BricsCAD 22
erstellt am: 07. Jun. 2017 10:36 <-- editieren / zitieren --> Unities abgeben:
Manchmal belastet mir AutoCAD trotz "Untätigkeit" einen Prozessor dauernd mit Volllast. Ich habe jetzt mit ProcMon nachgesehen - da laufen tausende Registryabfragen Code: "10:25:43.4925834","acad.exe","3364","RegOpenKey","HKCU\Software\Autodesk\AutoCAD\R21.0\ACAD-0001\Variables\CONTENTTYPEORDER","NAME NOT FOUND","Desired Access: Read" "10:25:43.4926018","acad.exe","3364","RegQueryKey","HKLM","SUCCESS","Query: HandleTags, HandleTags: 0x0" "10:25:43.4926219","acad.exe","3364","RegOpenKey","HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001:407\Variables\CONTENTTYPEORDER","NAME NOT FOUND","Desired Access: Read" "10:25:43.4926412","acad.exe","3364","RegQueryKey","HKLM","SUCCESS","Query: HandleTags, HandleTags: 0x0" "10:25:43.4926608","acad.exe","3364","RegOpenKey","HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001\Variables\CONTENTTYPEORDER","NAME NOT FOUND","Desired Access: Read" "10:25:43.4926805","acad.exe","3364","RegQueryKey","HKCU","SUCCESS","Query: HandleTags, HandleTags: 0x0" "10:25:43.4927002","acad.exe","3364","RegOpenKey","HKCU\SOFTWARE\Autodesk\ObjectDBX\R21.0\Variables\CONTENTTYPEORDER","NAME NOT FOUND","Desired Access: Read" "10:25:43.4927194","acad.exe","3364","RegQueryKey","HKLM","SUCCESS","Query: HandleTags, HandleTags: 0x0" "10:25:43.4927395","acad.exe","3364","RegOpenKey","HKLM\SOFTWARE\Autodesk\ObjectDBX\R21.0\Variables\CONTENTTYPEORDER","NAME NOT FOUND","Desired Access: Read" "10:25:43.4928174","acad.exe","3364","RegQueryKey","HKLM","SUCCESS","Query: HandleTags, HandleTags: 0x0" "10:25:43.4928387","acad.exe","3364","RegOpenKey","HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001:407\Variables\INPUTSEARCHOPTIONFLAGS","NAME NOT FOUND","Desired Access: Read"
Hat das einen ersichtlichen / allgemeinen Grund? ------------------ Für jedes Problem gibt es eine einfache Lösung. Die ist aber meistens falsch. ;-) Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
cadffm Moderator 良い精神
erstellt am: 07. Jun. 2017 11:17 <-- editieren / zitieren --> Unities abgeben: Nur für Peter2
Ich bin mir nicht sicher wonach du genau fragst, aber der Grund des "andauernd" wird wohl in der beschriebenen Tatsache liegen: Die Einträge sind nicht vorhanden/nicht lesbar. Das Programm (ver)sucht daher ständig an die Informationen zu kommen. Eine Reparatur-Installation wäre da wohl aus Benutzersicht der erste Schritt. FALLS ALLE ServicePacks/Hotfixes/Bugfixes(was immer es gibt) bereits installiert sind! Wenn es nicht zu viele verschiedene Einträge sind, dann ggf. auch per Hand ergänzen. Allerdings: Das sind ganz oder Teilweise Einträge die "nicht immer da sind", daher wäre auch mein erster Schritt die Rep.Installation. Wenn dieser Versuch nicht hilft, dann würde ich mich einem Eintrag nach dem anderen widmen und im schlimmsten Fall mit einem RegCleaner versuchen die Sache in den Griff zu bekommen.
------------------ CAD on demand GmbH - Beratung und Programmierung rund um AutoCAD Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 07. Jun. 2017 12:05 <-- editieren / zitieren --> Unities abgeben:
So mal als Zwischeninfo, ohne Reparatur: Manches fehlt, anderes hat ein Sternchen davor ... Code: "HKCU\Software\Autodesk\AutoCAD\R21.0\ACAD-0001\Variables\CONTENTTYPEORDER" -> nur zwei Var. mit *Sternchen davor"HKCU\SOFTWARE\Autodesk\ObjectDBX\R21.0\Variables\CONTENTTYPEORDER"-> Ordner Variables fehlt "HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001:407\Variables\CONTENTTYPEORDER" -> Ordner Variables fehlt "HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001:407\Variables\INPUTSEARCHOPTIONFLAGS" -> Ordner Variables fehlt "HKLM\Software\Autodesk\AutoCAD\R21.0\ACAD-0001\Variables\CONTENTTYPEORDER"-> Ordner mit Stern vorhanden HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0001\Variables\*CONTENTTYPEORDER "HKLM\SOFTWARE\Autodesk\ObjectDBX\R21.0\Variables\CONTENTTYPEORDER"-> Ordner Variables fehlt
Bernd P Ehrenmitglied V.I.P. h.c. cook-general
Beiträge: 3358 Registriert: 07.06.2001 W10-64bit, AMD Ryzen 7 3700X,32GB RAM, Sapphire Pulse Radeon RX 570 8G G5, Canon TX-3000 MFP, Maus Cherry MW4500, Sub:Infrastructure Design Suite, Office 365
erstellt am: 07. Jun. 2017 12:37 <-- editieren / zitieren --> Unities abgeben: Nur für Peter2
erstellt am: 07. Jun. 2017 13:40 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 07. Jun. 2017 15:52 <-- editieren / zitieren --> Unities abgeben:
Abschluss (bis auf weiteres): Die tausenden Registry-Einträge laufen auch, wenn die CPU auf 0.5% zurückgeht. Also sind die zumindest nicht für die CPU-Last zuständig ------------------ Für jedes Problem gibt es eine einfache Lösung. Die ist aber meistens falsch. ;-) Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
CADchup Ehrenmitglied V.I.P. h.c.
Beiträge: 3329 Registriert: 14.03.2001 Sicher ist, dass nichts sicher ist. Selbst das nicht. Joachim Ringelnatz
erstellt am: 08. Jun. 2017 09:29 <-- editieren / zitieren --> Unities abgeben: Nur für Peter2
Hi, Zitat: Original erstellt von cadffm: ...und im schlimmsten Fall mit einem RegCleaner versuchen die Sache in den Griff zu bekommen.
Woraufhin dann wieder eine Reparaturinstallation notwendig sein dürfte, die diese Einträge wieder erzeugt. Ein Teufelskreis. ;) Das Problem - wenn es denn tatsächlich eines ist - ist schon eine Weile bekannt, und wird, wie's scheint, von Autodesk mal wieder wegignoriert.
Zitat: Original erstellt von Peter2: Manchmal belastet mir AutoCAD trotz "Untätigkeit" einen Prozessor dauernd mit Volllast.
Das wurde noch nicht belegt. Wenn dem tatsächlich so sein sollte, lohnt sich vielleicht ein Blick auf den Contentexplorer. Dessen Dienst haben wir hier deaktiviert, weil er gerne die CPU überbeschäftigte und alle 10 Sekunden startete und wieder abbrach. Such' in der Windows Ereignisanzeige nach Fehlern des Autodesk Content Services. ( Knowledgebase-Artikel) Frage am Rande: Content Explorer - mal wieder am Bedarf vorbeientwickelt oder nutzt den tatsächlich irgendwer? Gruß CADchup
------------------ CADmaro.de [Diese Nachricht wurde von CADchup am 08. Jun. 2017 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jun. 2017 21:17 <-- editieren / zitieren --> Unities abgeben:
| Anzeige.:
