  EPLAN script does not work if space present in CLI argument value
Autor Thema:  EPLAN script does not work if space present in CLI argument value (1162 mal gelesen)
blitzkreig
Engineer
Sehen Sie sich das Profil von blitzkreig an!   Senden Sie eine Private Message an blitzkreig  Schreiben Sie einen Gästebucheintrag für blitzkreig
erstellt am: 21. Jan. 2019 05:27    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
When passing arguments through command line to EPLAN, if there is a space character in the value, then the quotes("") used to identify parameters are not correctly. This leads to missing parameters when EPLAN is being run, which causes script to fail.
Example:
"C:\Program Files\EPLAN\Electric P8\2.7.3\Bin\W3u.exe" ExecuteScript /ScriptFile:"script.cs" /path:"test.elk" /system:"Test system" /subsystem:"test"
EPLAN error when I run it:
Expected parameter 'subsystem' is missing. And the console output:
Code:
"C:\Program Files\EPLAN\Electric P8\2.7.3\Bin\W3u.exe" ExecuteScript /ScriptFile:"script.cs" /path:test.elk /system:"Test system /subsystem:test"
You can see Eplan automatically removes the quote in between, so subsystem parameter is inside system parameter quote, which is why it is missing. If I remove the space in the value passed to 'system' parameter as shown below, then script works:
Code:
"C:\Program Files\EPLAN\Electric P8\2.7.3\Bin\W3u.exe" ExecuteScript /ScriptFile:"script.cs" /path:"test.elk" /system:"Test_system" /subsystem:"test"
Console output:
Code:
"C:\Program Files\EPLAN\Electric P8\2.7.3\Bin\W3u.exe" ExecuteScript /ScriptFile:"script.cs" /path:test.elk /system:Test system /subsystem:test
So how do I fix this problems? Because of this issue, none of my parameter values can have spaces in them, even though I use double quotes to separate them.. Thanks!
cad_hans
Techn. Angestellter
ruplan4.70
eplan5.x
P8 V1.9 bis V2.7
erstellt am: 21. Jan. 2019 07:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für blitzkreig 10 Unities + Antwort hilfreich
hello,
why is it a Problem not to have spaces in your values?
i personally do not like spaces in names or values.
i always try to use some other characters to seperate the names if it has to be.
ruplan4.70
eplan5.x
P8 V1.9 bis V2.7
blitzkreig
Engineer
erstellt am: 21. Jan. 2019 07:52    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Original erstellt von cad_hans:
hello,
Sometimes customer will need spaces in some of these values. Also, sometimes I have to pass path of project as parameter, which usually always has a space in them, which cannot be avoided.
Maniax112
Anlagenplaner Maschinenbau
Sehen Sie sich das Profil von Maniax112 an!   Senden Sie eine Private Message an Maniax112  Schreiben Sie einen Gästebucheintrag für Maniax112
EPLAN P8 2.5 HF1
erstellt am: 17. Sep. 2019 09:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für blitzkreig 10 Unities + Antwort hilfreich
Any news about the problem??
I also try to find a solution.
pxecad
Sehen Sie sich das Profil von pxecad an!   Senden Sie eine Private Message an pxecad  Schreiben Sie einen Gästebucheintrag für pxecad
Electric P8 2.9.4 SP1 Update14
Electric P8 2023
Electric P8 2024
EEC Professional 2023 (Web EEC)
erstellt am: 17. Sep. 2019 09:48    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für blitzkreig 10 Unities + Antwort hilfreich
Hello,
i can not find any errors using EPLAN 2.7 HF7 and Windows 10 1803.
I just made a little script with your input parameters:
public class Script
[Start]
public void Test(string path, string system, string subsystem)
MessageBox.Show("Script works with parameter:" + "\npath:" + path + "\nsystem:" + system + "\nsubsystem:" + subsystem);
And started it with:
"E:\PROGRAMMEx64\Electric P8\2.7.3\Bin\W3u.exe" ExecuteScript /ScriptFile:"D:\P8_Script_1_Message_one_row_var.cs" /path:test.elk /system:"Test system With Space" /subsystem:"test"
Looks quite goood, with output in EPLAN Pop Up. See picture.
I think your qoutes are not at the right position.
[Diese Nachricht wurde von pxecad am 18. Sep. 2019 editiert.]
