  Error while Synchronizing Eplan Project stored part with System part database created
Autor Thema:  Error while Synchronizing Eplan Project stored part with System part database created (662 mal gelesen)
Prince1209
ECAD Standardization Specialist
Sehen Sie sich das Profil von Prince1209 an!   Senden Sie eine Private Message an Prince1209  Schreiben Sie einen Gästebucheintrag für Prince1209
Eplan 2.3
Eplan 2.6
Eplan 2.7
erstellt am: 08. Sep. 2017 13:32    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi There..
I need some help for the below topic..
Actually we are using Eplan 2.6 version with SQL database for part database as well as for translation database.. And recently we discovered that if we synchronize the Project stored part with System parts it is giving error Msg. "Item cannot be found in the collection corresponding to the requested name or ordinal." For few parts In the screenshot attached you can see the error Is appearing. But if I do the same thing with the same part no with some test database created In M.S. Access the synchronization works fine. We have already enabled the Unicode setting for SQL database, but still same result.
Can Somebody please Have a look to this.
Thanks and Regards
Prince
