Thema: Multilevel terminals numbering (1304 mal gelesen)
biroalfa Mitglied dipl.ing.elektrotechnik
Beiträge: 18 Registriert: 11.01.2010 Eplan 5.70 compact Eplan 1.8.1, 1.9.6 compact with mounting panel module Eplan 2.4 select 64 bit version 2.4 HF2 with mounting panel module
erstellt am: 06. Jul. 2015 00:17 <-- editieren / zitieren --> Unities abgeben:
Hello to all! Eplan P8 2.4 Is there possibility to number multilevel terminals (motor terminal with 3 line + PE), like Schrack http://www.schrack.com/shop/3-level-terminal-2-5mm2-type-puk3t-3p-p-ik680003.html with the same number for each consumer? For example, Motor 1 has X1=1,1,1,PE; then Motor 2 is X1=2,2,2,PE; etc. Whatever I tried, can't manage this simple task. Hope you'll understand the problem and someone will help.... Greetings! biroalfa ------------------ Eplan 5.70 compact Eplan 1.8.1, 1.9.6 compact with mounting panel module Eplan 2.4 select 64 bit version 2.4 HF2 with mounting panel module Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
HKXVZBi Ehrenmitglied Konstruktion Elektroplanung
Beiträge: 1502 Registriert: 27.01.2010 i7-3770 3.40GHz, 16GB RAM Radeon Pro WX5100 3xHP Z27n G2 Software: MS Win 10 64Bit MS Office 2010/365 ------ ePlan Electric P8 Menüumfang: ǝʇɹǝdxǝ
erstellt am: 06. Jul. 2015 07:56 <-- editieren / zitieren --> Unities abgeben: Nur für biroalfa
Hello this semms to be difficult i tried several ways at first i placed four terminals with the designation 1/1/1/PE then i duplicated this terminals and renumberd them automatically by eplan, this works very well next i tried to renumber an existing terminal, therfor you had to set the parameter "allow same designation" (didnt' know if ist't correct translated) in your settings for terminal numbering you also had to set the point "Multilevelterminal: equal numbering" i atteched a picture with my settings ------------------ Gruß Marco --------------------------------- Es gibt Dinge im Leben die kommen und gehen, aber Ruhm und Fitness bleiben einem für immer erhalten! Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 06. Jul. 2015 10:49 <-- editieren / zitieren --> Unities abgeben:
Thank you for quick answer! Pity, it doesn't work in current (huge) project. Will try next time from the beginning copying terminals, then renumbering like you did, but now I have to finish my work and deliver to customer. Since I'm in a hurry (before vacation), have no time to go from beginning. To try your advice in this moment, first I should rename terminals naming them with the same number, then, rename them in a manner you suggested. I tried this, but don't know why can't rename them naming them with same number, so I gave up (for now). Once again, thank you for your effort and time... biroalfa ------------------ Eplan 5.70 compact Eplan 1.8.1, 1.9.6 compact with mounting panel module Eplan 2.4 select 64 bit version 2.4 HF2 with mounting panel module Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 06. Jul. 2015 10:56 <-- editieren / zitieren --> Unities abgeben: Nur für biroalfa
ok, another way to number multilevelterminals is to filter each level and number them seperatly ------------------ Gruß Marco --------------------------------- Es gibt Dinge im Leben die kommen und gehen, aber Ruhm und Fitness bleiben einem für immer erhalten! Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 06. Jul. 2015 10:58 <-- editieren / zitieren --> Unities abgeben:
Interesting, of course... Thanks! biralfa ------------------ Eplan 5.70 compact Eplan 1.8.1, 1.9.6 compact with mounting panel module Eplan 2.4 select 64 bit version 2.4 HF2 with mounting panel module Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
