  2D Panel Guidance?
Autor Thema:  2D Panel Guidance? (789 mal gelesen)
calebxx12
Designer
Sehen Sie sich das Profil von calebxx12 an!   Senden Sie eine Private Message an calebxx12  Schreiben Sie einen Gästebucheintrag für calebxx12
erstellt am: 23. Jul. 2014 13:07    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hey everyone, hopefully there are some English speaking people here,
We are drastically under-utilizing ePlan as of right now, but only because we are not 100% certain how to use the 2D Panel Builder. We are using AutoCAD for our panels right now because ti is easier to draw in. We do not need the 3D option so Pro Panel is not for us.
Does anyone have a good beginner tutorial on how to build a detailed looking panel in ePlan? Right now we can do it a little, but noting production quality.
Some main points we are missing on are:
1. Parts are not covering lines below.
2. Can't trim easily.
3. Nested parts (2 parts in one, as in a fuse holder and fuse) aren't adding properly.
4. How to make a mounting rail on a mounting panel.
Those are just a few concerns. My main goal is to do everything in ePlan, so does anyone know of any good tutorials or anything? Thanks!
robroy55
Elcad V5/V7 Prof.
Eplan V5/P8 Prof.
Sigraph(SPEL-D) V5/V8/V9/V10
Wscad V4/V5/Suite Prof.
Ruplan V4.7/V4.8 Std/EVU
Autocad LT 2007
erstellt am: 23. Jul. 2014 16:01    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für calebxx12 10 Unities + Antwort hilfreich
Hi calebxx12 and welcome to the board,
maybe its better for you to look at this board.
There are a lot of examples and tutorials for Eplan P8. This is a additional board from the mod of this board. Before you can use it you have to register.
Grüße aus Frangn
Rob
Habe keine Angst etwas Neues im Leben auszuprobieren.
Denke einfach daran, dass Amateure die Arche erbaut haben und Profis die Titanic.
[Diese Nachricht wurde von robroy55 am 23. Jul. 2014 editiert.]
calebxx12
Designer
erstellt am: 23. Jul. 2014 17:31    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Thank you for the information! I browsed that site and found some stuff but not a whole lot on panel building sadly , thanks again though~
