man kann ja in einer Tabular Note den projection angle per Syntax <W@$SH_SHEET_PROJECTION_ANGLE> anzeigen lassen.
Das klappt aber nur wenn die Tabular Note eine gewisse Größe hat, sonst wird das Symbol nicht gezeigt.
Dazu gibt es auch einen bestehenden ER.
Vielleicht möchte sich ja da jemand anhängen.
ER Text
See existing ER-6437060.
1. Short Description:
Can't have a user defined scale size for <W@$SH_SHEET_PROJECTION_ANGLE>.
2. What activity in your process is NX not able to currently handle?
3. What result are you trying to achieve?
Currently the projection angle displays a user defined symbol, with no method to scale it in a note.
Require the projection angle <W@$SH_SHEET_PROJECTION_ANGLE> allow users to set a scale factor per individual drawing sheets in a part file.
4. Do you currently have a workaround? If yes, please describe it.
No
5. Do you have a proposal for the solution you envision NX providing for this capability?
Add ability to scale referenced system symbols OR even beter allow to insert custom symbols into tabular notes / title blocks which can be scaled easily.
6. How much of an impact would this enhancement have on the workflow in your scenario?
High
7. How often does this effect users in your organization?
Daily (using drawing template)
8. How many users in your organization are affected?
21-100
Grüße,
