sorry mein fehler.
hier die parameter:
Wert: C:\Program Files\aucotec\cae\usr_deu\PTD.720\KONVERT.CFG
# ********** Configuration file for DXF Import/Export **********
# ********** VNS Import/Export **********
# ******** Start of the definition of the variables for CONVERT ********
# ==== Definition of variables for DXF Import ====
DXF_ZEICHNUNGS_EBENEN |DXF|PTD|IMPORT|
DXF_FORMBLATT_LAYER SF
DXF_SYMBOLART_DEF STANDARD
DXF_LIN_ART_DEF CONTINUOUS
DXF_LIN_BREITE_DEF 0.18
DXF_ANSCHLUSS_KENNUNG ANSCHLUSS
# --- For advanced users ---
# DXF_TEXTBEZUG_X -0.1
# DXF_TEXTBEZUG_Y -0.5
# DXF_CHARSET_IN PC_8
# ==== Definition of variables for DXF Export ====
DXF_PEN1_COLOR 1 # Elcad Pen 1 Color number f. DXF Export
DXF_PEN2_COLOR 2 # Elcad Pen 2 Color number f. DXF Export
DXF_PEN3_COLOR 3 # Elcad Pen 3 Color Number f. DXF Export
DXF_PEN4_COLOR 4 # Elcad Pen 4 Color Number f. DXF Export
DXF_PEN5_COLOR 5 # Elcad Pen 5 Color Number f. DXF Export
DXF_PEN6_COLOR 6 # Elcad Pen 6 Color Number f. DXF Export
DXF_PEN7_COLOR 7 # Elcad Pen 7 Color Number f. DXF Export
DXF_PEN8_COLOR 8 # Elcad Pen 8 Color Number f. DXF Export
# ==== Definition of variables for VNS Import ====
VNS_LIN_ART_DEF 1
VNS_LIN_BREITE_DEF 1
# VNS_USYMBOL_REF 0 # 0 = Sub symbol graphics when resolved
# VNS_USYMBOL_REF 1 # (1) = Sub symbol call for output
VNS_ALWAYS_TA 0
VNS_COUNT_SEP _
# VNS_TEXTBEZUG_X -0.2
# VNS_TEXTBEZUG_Y -0.2
# ==== Definition of variables for ELCAD ASCII Export ====
EAS_SYMTYP_DEF 1
EAS_CODENR_DEF 51
EAS_FORMBLATT_DEF FBDXFIN
EAS_LIN_ART_DEF 1
EAS_STIFT_DEF 1
EAS_X_GRAFIK 420 # DIN A3
EAS_Y_GRAFIK 297 # DIN A3
# EAS_X_GRAFIK 594 # DIN A2
# EAS_Y_GRAFIK 420 # DIN A2
# EAS_X_GRAFIK 841 # DIN A1
# EAS_Y_GRAFIK 594 # DIN A1
# EAS_X_GRAFIK 1189 # DIN A0
# EAS_Y_GRAFIK 841 # DIN A0
EAS_GESAMT_MASSSTAB 0 # Auto scaling
# EAS_GESAMT_MASSSTAB 1 # Scale 1:1
EAS_PLAN_X_OFFSET 0
EAS_PLAN_Y_OFFSET 0
EAS_TEXT_UNSICHTBAR UNSICHTBAR
EAS_VERB_PLR 0 # (0)= No 1 = Yes
EAS_MECHVERB_PLR 0 # (0)= No 1 = Yes
# EAS_CODE_BEDEUTUNG_TA 0 # (0)= TA-meaning | CFG | TA-designation
# EAS_CODE_BEDEUTUNG_TA 1 # 1 = TA-meaning | TA-designation
# EAS_CODE_BEDEUTUNG_TA 2 # 2 = TA-designation
# EAS_CODE_BEDEUTUNG_TA 3 # 3 = CFG | TA-designation
# EAS_CODE_BEDEUTUNG_DEF (Default)
# EAS_USYMBOL_REF 0 # (0)= Sub symbol graphics when resolved
# EAS_USYMBOL_REF 1 # 1 = Sub symbol call for output
# EAS_TA_DIFF_REF 0 # (0)= Fixed texts
# EAS_TA_DIFF_REF 1 # 1 = Symbol texts
# EAS_LAYER_KEY 0 # Transfer without layer structure
# EAS_LAYER_KEY 1 # Transfer with layer structure
# EAS_PSEUDONAME_CODENR 999 # Code f. Symbol name (Original)
# ******** End of the definition of variables for CONVERT ********
# **************** Start of the CONVERT transfer lists *****************
# ==== Assignation between DXF labels and VNS labels ====
# -- DXF-Code ==> VNS-Code (according to respective DIN system specs.) --
START:CODENR_DXF_VNS
CODE_1 =
CODE_2 =.
CODE_3 +
CODE_4 -
CODE_5 ==
CODE_6 =.=.
CODE_7 ++
CODE_8 -1
CODE_9 +.
CODE_10 L
CODE_12 ID
CODE_21 :
CODE_23 ELC_QUERSCHNITT_Z_ANSCHLUSS
CODE_30 P1
CODE_30 TD
CODE_31 P2
CODE_32 P3
CODE_33 33TD
CODE_34 34TD
CODE_35 35TD
CODE_36 36TD
CODE_37 37TD
CODE_38 38TD
CODE_39 FARBE
CODE_40 TX
CODE_42 42TD
CODE_50 50TX
CODE_51 51TX
CODE_52 52TX
CODE_53 53TX
CODE_54 54TX
CODE_55 55TX
CODE_56 56TX
CODE_57 57TX
CODE_58 58TX
CODE_59 59TX
CODE_60 ULNR1
CODE_61 ULNR2
CODE_62 BLATT
CODE_63 ULNR3
CODE_64 ULNR4
CODE_65 BEN1
CODE_66 BEN2
CODE_67 AGTX
CODE_68 ZNRA
CODE_69 S
CODE_70 ELC_FOLGEBLATT
CODE_71 SANZ
CODE_72 ERDAT
CODE_73 URSPR
CODE_74 ERSF
CODE_75 ERSD
CODE_76 &
CODE_77 SONDV1
CODE_78 ELC_MASCHINENTYPE
CODE_79 ELC_PFAD
CODE_80 NO
CODE_81 ELC_82NO
CODE_90 ELC_SYMBOLMAKRO_M_ABFRAGE
CODE_91 ELC_SYMBOLMAKRO_O_ABFRAGE
CODE_92 ELC_EAS_ANZEIGE
CODE_149 ELC_MENGE
CODE_150 ELC_BEZEICHNUNG
CODE_151 ELC_HERSTELLER
CODE_152 ART
CODE_165 PTD_TYPE_OF_DOCUMENT
CODE_166 PTD_NAME_3
CODE_167 PTD_LETTER_BLOCK_3
CODE_168 PTD_NUM_PART_BLOCK_3
CODE_169 PTD_TOTAL_DRAWING_NO
CODE_170 PTD_CREATION_DATE
CODE_171 PTD_DRAWN_BY
CODE_172 PTD_CHECKED_BY
CODE_173 PTD_STANDARD
CODE_174 PTD_ORIGINATOR
CODE_175 PTD_OPERATOR
CODE_176 PTD_HIGHER_LEVEL_DES
CODE_177 PTD_CUSTOMER_ORDER_NO
CODE_178 PTD_YEAR_OF_COPYRIGHT
CODE_179 PTD_PROJECT
CODE_180 PTD_DOCUMENT_TYPE_EXT
CODE_181 PTD_SYM_LIB_1
CODE_182 PTD_SYM_LIB_2
CODE_183 PTD_SYM_LIB_3
CODE_184 PTD_SYM_LIB_4
CODE_185 PTD_TRANSL_A
CODE_186 PTD_TRANSL_B
CODE_188 PTD_TRANSL_D
CODE_189 PTD_ELCAD_VERSION
CODE_190 PTD_STAND_WIRE_ST_TEXT
CODE_191 PTD_STAND_WIRE_2ND_ALNG_ST_TEXT
CODE_193 PTD_HIGHER_LEVEL_ARCHIV
CODE_194 PTD_STAND_WIRE_END_TEXT
CODE_195 PTD_STAND_WIRE_2ND_ALNG_END_TEXT
CODE_196 PTD_CUST_DRWG_NO_PART1
CODE_197 PTD_CUST_DRWG_NO_PART2
CODE_301 ELC_KLEMMENTEXT_ANSCHLUSSPLAN
CODE_302 ELC_ZIELZEICHEN_EXT
CODE_304 ELC_ZIELZEICHEN_INT
CODE_306 ELC_LEISTEN_NAME
CODE_307 ELC_KLEMMEN_ANZAHL
CODE_362 ELC_ADERBEZEICHNUNG
CODE_363 ELC_ADERTYP
CODE_364 ELC_ADERQUERSCHNITT
CODE_365 ELC_KABELNAME
CODE_366 ELC_ADERANZAHL
CODE_367 ELC_KABELTYP
CODE_368 ELC_ADERFARBE
CODE_372 ELC_LEITUNGSTYP
CODE_373 ELC_LEITUNGSQUERSCHNITT
CODE_402 PTD_ACTUAL_STATUS
CODE_403 PTD_ACTUAL_REVISION
CODE_404 PTD_ACTUAL_DATE
CODE_405 PTD_ACTUAL_NAME
CODE_450 PTD_A_STATUS
CODE_451 PTD_A_REVISION
CODE_452 PTD_A_DATE
CODE_453 PTD_A_NAME
CODE_454 PTD_B_STATUS
CODE_455 PTD_B_REVISION
CODE_456 PTD_B_DATE
CODE_457 PTD_B_NAME
CODE_458 PTD_C_STATUS
CODE_459 PTD_C_REVISION
CODE_460 PTD_C_DATE
CODE_461 PTD_C_NAME
CODE_462 PTD_D_STATUS
CODE_463 PTD_D_REVISION
CODE_464 PTD_D_DATE
CODE_465 PTD_D_NAME
CODE_1003 ELC_HILFSVARIABLE
CODE_3021 ELC_SL_RECORD
CODE_3200 ELC_SYMDOKU_BIBLIOTHEK
CODE_3201 ELC_SYMDOKU_SYMBOLNAME
CODE_3202 ELC_SYMDOKU_BLATTNUMMER
CODE_3203 ELC_SYMDOKU_SYMBOLKOMMENTAR
CODE_3204 ELC_SYMDOKU_SYMBOLTYP
CODE_3205 ELC_SYMDOKU_DATUM_D_BIBLIOTHEK
CODE_3206 ELC_SYMDOKU_DATUM_D_SYMBOLS
CODE_3207 ELC_SYMDOKU_FOLGESEITE
CODE_3208 ELC_SYMDOKU_MASSSTAB
CODE_4003 ELC_HOEHE
CODE_4004 ELC_BREITE
CODE_4005 ELC_TIEFE
CODE_4006 ELC_MASSSTAB
CODE_4007 ELC_PRE_DX
CODE_4008 ELC_POST_DX
CODE_4009 ELC_PRE_DY
CODE_4010 ELC_POST_DY
CODE_4011 ELC_ANSCHLUSSPLANSYMBOL
CODE_10001 ELC_ZIEL_EXT_ANLAGE
CODE_10002 ELC_ZIEL_EXT_ORT
CODE_10003 ELC_ZIEL_EXT_FUNKTION
CODE_10004 ELC_ZIEL_EXT_BMK
CODE_10021 ELC_ZIEL_EXT_ANSCHLUSS
CODE_10040 ELC_ZIEL_EXT_KOMMENTAR
CODE_11001 ELC_ZIEL_INT_ANLAGE
CODE_11002 ELC_ZIEL_INT_ORT
CODE_11003 ELC_ZIEL_INT_FUNKTION
CODE_11004 ELC_ZIEL_INT_BMK
CODE_11021 ELC_ZIEL_INT_ANSCHLUSS
CODE_11040 ELC_ZIEL_INT_KOMMENTAR
ENDE:CFG_LISTE
# ==== Assignation between ELCAD code number and VNS label ====
# -ELCAD-Code <==> VNS-Code (according to respective DIN system specs.)
# ELCAD |VNS |Comment
START:CODENR_EAS_VNS
0 GA VNS: Graphics representation
1 = Higher level designation
2 =. Function
3 + Location
4 - Item designation
5 == Super higher level designation
6 =.=. Super function
7 ++ Super location
8 -1 Super item designation
9 +.
10 L Cross reference/reference
12 ID
21 : Terminal pin
30 P1 Voltage
30 TD
31 P2 Current
32 P3 Power
33 33TD Rotations
34 34TD Resistance
35 35TD Capacity
36 36TD Inductance
37 37TD Primary voltage
38 38TD Secondary voltage
39 FARBE Color
40 TX Item comment
42 42TD Technical data
50 50TX General Text
51 51TX General Text
52 52TX General Text
53 53TX General Text
54 54TX General Text
55 55TX General Text
56 56TX General Text
57 57TX General Text
58 58TX General Text
59 59TX General Text
60 ULNR1 Designation level
61 ULNR2 Designation level
62 BLATT Page number (last level !)
63 ULNR3 Designation level
64 ULNR4 Designation level
65 BEN1 Page name
66 BEN2 Project name
67 AGTX Client
68 ZNRA Client's drawing number
69 S Page
70 ELC_FOLGEBLATT Next page
71 SANZ Pages
72 ERDAT Date
73 URSPR Origin
74 ERSF Replacement for
75 ERSD Replaced by
76 & Diagram type
77 SONDV1 Special notes
78 ELC_MASCHINENTYPE Machine type
79 ELC_PFAD Path
80 NO Part number
81 ELC_82NO Combined part number
90 ELC_SYMBOLMAKRO_M_ABFRAGE Variable macro (with query)
91 ELC_SYMBOLMAKRO_O_ABFRAGE Variable macro (without query)
92 ELC_EAS_ANZEIGE External macro
149 ELC_MENGE Quantity
150 ELC_BEZEICHNUNG Designation
151 ELC_HERSTELLER Manufacturer
152 ART Kind of item
166 PTD_NAME_3
171 PTD_DRAWN_BY
172 PTD_CHECKED_BY
173 PTD_STANDARD
174 PTD_ORIGINATOR
175 PTD_OPERATOR
179 PTD_PROJECT
181 PTD_SYM_LIB_1
182 PTD_SYM_LIB_2
183 PTD_SYM_LIB_3
184 PTD_SYM_LIB_4
185 PTD_TRANSL_A
186 PTD_TRANSL_B
188 PTD_TRANSL_D
302 ELC_ZIELZEICHEN_EXT External destinations
304 ELC_ZIELZEICHEN_INT Internal destinations
306 ELC_LEISTEN_NAME Terminal block designation
307 ELC_KLEMMEN_ANZAHL Number of terminals
362 ELC_ADERBEZEICHNUNG Core designation
363 ELC_ADERTYP Core type
364 ELC_ADERQUERSCHNITT Core cross section
365 ELC_KABELNAME Cable names
366 ELC_ADERANZAHL Number of cores
367 ELC_KABELTYP Cable type
368 ELC_ADERFARBE
372 ELC_LEITUNGSTYP Wire type
373 ELC_LEITUNGSQUERSCHNITT Wire cross section
404 PTD_ACTUAL_DATE
405 PTD_ACTUAL_NAME
450 PTD_A_STATUS
451 PTD_A_REVISION
452 PTD_A_DATE
453 PTD_A_NAME
454 PTD_B_STATUS
455 PTD_B_REVISION
456 PTD_B_DATE
457 PTD_B_NAME
458 PTD_C_STATUS
459 PTD_C_REVISION
460 PTD_C_DATE
461 PTD_C_NAME
462 PTD_D_STATUS
463 PTD_D_REVISION
464 PTD_D_DATE
465 PTD_D_NAME
1003 ELC_HILFSVARIABLE Auxiliary variable
3021 ELC_SL_RECORD Component list flag (layout symbol)
3203 ELC_SYMDOKU_SYM BOLKOMMENTAR
4003 ELC_HOEHE Height
4004 ELC_BREITE Width
4005 ELC_TIEFE
4006 ELC_MASSSTAB Scaling: scale
4007 ELC_PRE_DX Relocation Pre_dx
4008 ELC_POST_DX Relocation Post_dx
4009 ELC_PRE_DY Relocation Pre_dy
4010 ELC_POST_DY Relocation Post_d
4011 ELC_ANSCHLUSSPLANSYMBOL Symbol name - connection plan
10001 ELC_ZIEL_EXT_ANLAGE Dest. 1 higher-level designation (ext.)
10002 ELC_ZIEL_EXT_ORT Dest. 1 function (external)
10003 ELC_ZIEL_EXT_FUNKTION Dest. 1 location (external)
10004 ELC_ZIEL_EXT_BMK Dest. 1 item designation (external)
10021 ELC_ZIEL_EXT_ANSCHLUSS Dest. 1 terminal (external)
10040 ELC_ZIEL_EXT_KOMMENTAR Dest. 1 comment
11001 ELC_ZIEL_INT_ANLAGE Dest. 2 higher-level designation (int.)
11002 ELC_ZIEL_INT_ORT Dest. 2 function (internal)
11003 ELC_ZIEL_INT_FUNKTION Dest. 2 location (internal)
11004 ELC_ZIEL_INT_BMK Dest. 2 item designation (internal)
11021 ELC_ZIEL_INT_ANSCHLUSS Destinations terminal (internal)
11040 ELC_ZIEL_INT_KOMMENTAR Destinations comment
ENDE:CFG_LISTE
# -- ELCAD code number <==> ELCAD dialogue description --
# -- max. 20 character --
START:EAS_CODE_BEDEUTUNG
1 H_level_designat
2 Function
3 Location
4 Item_designation
5 Super_h_level_des
6 Super_function
7 Super_location
8 Super_item_design
9 Mounting location
10 Cross_reference
21 Terminal_pin
30 Voltage
31 Current
32 Power
33 Rotations
34 Resistance
35 Capacity
36 Inductance
37 Primary_voltage
38 Secondary_voltage
39 Color
40 Item_comment
41 Type
42 Technical_data
48 Pressure
49 Nominal_size
51 General_text
60 Designation_level
61 Designation_level
62 Page_number
63 Designation_level
64 Designation_level
65 Page_name
66 Project_name
67 Client
68 Client's_drawing_no
69 Page
70 Next_page
71 Pages
72 Date
73 Origin
74 Replacement_for
75 Replaced_by
76 Diagram_type
77 Special_notes
78 Machine_type
79 Path
80 Part_number
81 Combined_part_number
82 Variant_part_number
90 Var_macro_with_query
91 Var_macro_no_query
100 Price
149 Quantity
150 Designation
151 Manufacturer
152 Kind_of_item
362 Core_designation
363 Core_type
364 Core_cross_section
365 Cable_names
366 Number_of_cores
367 Cable_type
372 Wire_type
373 Wire_cross_section
ENDE:CFG_LISTE
# -- DXF symbol type <--> VNS symbol type --
START:SYMTYP_DXF_VNS
0 STANDARD-0
1 STANDARD
2 STANDARD-ALLG
3 ABBRUCH
4 STANDARD-POT
5 STANDARD-MUTTER
6 STANDARD-TOCHTER
7 KLEMME
8 STANDARD-ADER
9 SCHRIFTFELD
10 EINBAUORT-FENSTER
11 SUPER-FENSTER
12 STANDARD-SPS
13 STANDARD-KABEL
14 STANDARD-POTD
ENDE:CFG_LISTE
# -- ELCAD symbol type <==> VNS symbol type --
START:SYMTYP_EAS_VNS
0 STANDARD-0
1 STANDARD General
2 STANDARD-ALLG Graphics (only)
3 ABBRUCH Connector symbol
4 STANDARD-POT Busbar potential
5 STANDARD-MUTTER Master device
6 STANDARD-TOCHTER Slave device
7 KLEMME Terminal/Plug/Socket
8 STANDARD-ADER Wire/Core symbol
9 SCHRIFTFELD Form sheet
10 EINBAUORT-FENSTER Location window
11 SUPER-FENSTER Super window
12 STANDARD-SPS PLC card
13 STANDARD-KABEL Cable symbol
14 STANDARD-POTD Wire potential
ENDE:CFG_LISTE
# -- ELCAD-Symboltyp <== VNS-Symboltyp (ueber SD-SA Satz) --
# ELCAD |VNS |Kommentar
START:SYMTYP_EAS_SDSA
1 SY-ART-WANDLE transducer
1 SY-ART-KONDEN capacitor
2 SY-ART-BINELE binary element
1 SY-ART-BELEUC light
1 SY-ART-VERBRA consumer
1 SY-ART-SCHMEL fuse
1 SY-ART-SICREL protecting relay
1 SY-ART-GENERA generator
1 SY-ART-BATTER accumulator
1 SY-ART-MELDER indicator
5 SY-ART-RELAIS relay
1 SY-ART-INDUKT Inductor
1 SY-ART-MOTORE motor
1 SY-ART-REGLER control device
1 SY-ART-MESGER measuring instrument
1 SY-ART-WIDERS resistor
1 SY-ART-SCHALT switch
1 SY-ART-DRESCH rotational switch
1 SY-ART-TRAFOS transformer
2 SY-ART-VERBIN connecting element
7 SY-ART-KLEMME terminal
7 SY-ART-STECKE plug in contact
1 SY-ART-FILTER filter
1 SY-ART-VENTIL valve
1 SY-ART-PUMPE pump
1 SY-ART-MASCHI machine
1 SY-ART-HILFSM auxiliary motor
12 SY-ART-SPS PLC
12 SY-ART-SPSANS PLC subassembly
1 SY-ART-SONSTI others
4 SY-ART-EINSPG feed in (connector)
2 SY-ART-ERDE earth
2 SY-ART-EXCLUS exclusiv input/output (connector)
6 SY-ART-LEGEND legend (hint)
2 SY-ART-SCHIEN busbar
9 SY-ART-STEMPE writing field
3 SY-ART-ABBAUS output of a connector (connector)
3 SY-ART-ABBEIN input of a connector (connetcor)
3 SY-ART-ABBRUC
12 SY-ART-AUSGAN output
12 SY-ART-EINGAN input
1 SY-ART-AUSLOE release
6 SY-ART-WECHSL change over
1 SY-ART-VERSOR PLC power supply
6 SY-ART-OEFFNE normally closed
6 SY-ART-SCHLIE normally opened
6 SY-ART-WECHS change over
ENDE:CFG_LISTE
# -- DXF line type ==> VNS line type --
START:LINART_DXF_VNS
# ================ Line types ==================
# *** AutoCAD ******** *** VNS ************
AUSGEZOGEN 1 # ______________________ Continuous (solid)
PUNKT 3 # . . . . . . . . . . . Dotted
PUNKT2 3 # ...................... Dotted
PUNKTX2 3 # . . . . . . . . Dotted
GESTRICHELT 5 # __ __ __ __ __ __ __ _ ** Free definition **
GESTRICHELT2 2 # _ _ _ _ _ _ _ _ _ _ _ Dashed
GESTRICHELTX2 6 # ____ ____ ____ ____ ** Free definition **
VERDECKT 5 # __ __ __ __ __ __ __ _ ** Free definition **
VERDECKT2 2 # _ _ _ _ _ _ _ _ _ _ _ Dashed
VERDECKTX2 6 # ____ ____ ____ ____ __ ** Free definition **
MITTE 7 # ____ _ ____ _ ____ _ _ ** Free definition **
MITTE2 7 # ___ _ ___ _ ___ _ ___ ** Free definition **
MITTEX2 7 # ________ __ ________ ** Free definition **
STRICHPUNKT 4 # __ . __ . __ . __ . __ Dashed/dotted
STRICHPUNKT2 4 # _._._._._._._._._._._. Dashed/dotted
STRICHPUNKTX2 4 # ____ . ____ . ____ Dashed/dotted
RAND 4 # __ __ . __ __ . __ __ Dashed/dotted
RAND2 4 # __.__.__.__.__.__.__._ Dashed/dotted
RANDX2 4 # ____ ____ . ____ _ Dashed/dotted
GETRENNT 8 # ____ . . ____ . . ____ ** Free definition **
GETRENNT2 8 # __..__..__..__..__..__ ** Free definition **
GETRENNTX2 8 # ________ . . ______ ** Free definition **
PHANTOM 8 # ______ __ __ ______ ** Free definition **
PHANTOM2 8 # ___ _ _ ___ _ _ ___ _ ** Free definition **
PHANTOMX2 8 # ____________ ____ ** Free definition **
CONTINUOUS 1 # ______________________ Continuous (solid)
DASHED 5 # __ __ __ __ __ __ __ _ ** Free definition **
DASHED2 2 # _ _ _ _ _ _ _ _ _ _ _ Dashed
DASHEDX2 6 # ____ ____ ____ ____ ** Free definition **
DOT 3 # . . . . . . . . . . . Dotted
DOT2 3 # ...................... Dotted
DOTX2 3 # . . . . . . . . Dotted
HIDDEN 5 # __ __ __ __ __ __ __ _ ** Free definition **
HIDDEN2 2 # _ _ _ _ _ _ _ _ _ _ _ Dashed
HIDDENX2 6 # ____ ____ ____ ____ __ ** Free definition **
CENTER 7 # ____ _ ____ _ ____ _ _ ** Free definition **
CENTER2 7 # ___ _ ___ _ ___ _ ___ ** Free definition **
CENTERX2 7 # ________ __ ________ ** Free definition **
CENTRE 7 # ____ _ ____ _ ____ _ _ ** Free definition **
CENTRE2 7 # ___ _ ___ _ ___ _ ___ ** Free definition **
CENTREX2 7 # ________ __ ________ ** Free definition **
DASHDOT 4 # __ . __ . __ . __ . __ Dashed/dotted
DASHDOT2 4 # _._._._._._._._._._._. Dashed/dotted
DASHDOTX2 4 # ____ . ____ . ____ Dashed/dotted
BORDER 4 # __ __ . __ __ . __ __ Dashed/dotted
BORDER2 4 # __.__.__.__.__.__.__._ Dashed/dotted
BORDERX2 4 # ____ ____ . ____ _ Dashed/dotted
DIVIDE 8 # ____ . . ____ . . ____ ** Free definition **
DIVIDE2 8 # __..__..__..__..__..__ ** Free definition **
DIVIDEX2 8 # ________ . . ______ ** Free definition **
# *** ELCAD-DXF ****** ****** VNS ***********
LTY0 0 # Invisible ** Free definition **
LTY1 1 # ______________________ Continuous (solid)
LTY2 3 # . . . . . . . . . . . Dotted
LTY3 2 # - - - - - - - - - - - Dashed
LTY4 7 # -- -- -- -- -- -- -- - ** Free definition **
LTY5 6 # --- --- --- --- --- -- ** Free definition **
LTY6 7 # --- - --- - --- - --- ** Free definition **
LTY7 4 # --- . --- . --- . --- Dashed/dotted
LTY8 8 # ---- - - ---- - - ---- ** Free definition **
ENDE:CFG_LISTE
# -- ELCAD line type <== VNS line type --
START:LINART_EAS_VNS
# *** ELCAD ******** ******** VNS ***********
1 1 # _______________________ Continuous (solid)
2 3 # . . . . . . . . . . . . Dotted
3 2 # - - - - - - - - - - - - Dashed
4 5 # -- -- -- -- -- -- -- -- ** Free definition **
5 6 # --- --- --- --- --- --- ** Free definition **
6 7 # --- - --- - --- - --- - ** Free definition **
7 4 # --- . --- . --- . --- . Dashed/dotted
ENDE:CFG_LISTE
# -- DXF layer name ==> ELCAD line width --
START XF_LAYER_LIBR
PEN1 0.35
PEN2 0.25
PEN3 0.5
PEN4 0.18
PEN5 0.7
PEN6 0.2
ENDE:CFG_LISTE
# -- DXF layer names which SHOULD be converted --
# START:LAYER_ON
# ENDE:CFG_LISTE
# -- DXF layer names which should NOT be converted --
# START:LAYER_OFF
# ENDE:CFG_LISTE
# ***************** End of the CONVERT transfer lists ******************
mfg Markus
[Diese Nachricht wurde von Markus_SIE am 17. Jan. 2005 editiert.]
