  DesignCAD
  Create 2D surface from a 3D object
Autor Thema:  Create 2D surface from a 3D object (388 / mal gelesen)
Typografia
Sehen Sie sich das Profil von Typografia an!   Senden Sie eine Private Message an Typografia  Schreiben Sie einen Gästebucheintrag für Typografia
erstellt am: 29. Aug. 2018 16:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I created an nice coffee mug in Autodesk Alias as you can see on the attachment. Now I want to place a certain pattern on the surface. The pattern displays figures and shall surroung the mug.
To place the pattern right sized I would like to get an 2D template which is exactly the measurements of the mug.  As attachment you can see a sketch of the desired template.
My Question: How can I get the surface mug form as 2D patch pane?
Imagine I cut to the surface as a thin plane an place it on the ground.
How can I do this?
As way back I want to place the pattern exactly on the mug. To do that I want to buckle the pattern to fit exactly on the mug.
Please help me!
I am also used in Catia V5.
