This Maintenance Pack addresses the following PRs:
===API===
PR 2188413: Geometry from addin unexpectedly being removed from UnDo on Next command
PR 1903366: Replace via API does not work as via User Interface
PR 1891179: GetGlobalParameter (..glMinimumFlatLength) always delivers 0.0025
PR 1875930: API - wrong Text Box Width and Weight when adding multi line text
PR 2201222: problem with the method of reading and changing the dimension style by API
PR 2201877: API: Parent Object of the fill pattern cannot be acquired
===Assembly===
PR 1901251: FOA file aborts on open
PR 1902643: Pattern fails to update correctly when used with family of assemblies
PR 2198695: Positioning of node in Frame Simulation always offsets from Line End 1
PR 1903074: QAT will be deleted after modification
PR 6608469: displaying subassembly parts.
PR 1900020: display issues after locating dimensions in Assemble
PR 1907507: Failing relationships when assembly features are recomputed in ST4
PR 2197077: Error - No License - WEBPUBLISHER
PR 6623403: Conflicting error message on feature compute.
PR 1903013: Missing override body information caused assembly features to not be visible
PR 1906702: Cannot place connect relation in some workflows
PR 1902264: A reproducible crash on redo after deleting assembly features
PR 6769819: Assembly file not shrinking as expected when components are deleted
PR 6769125: Multiple Solutions dialog one hour after updating all links
PR 2201912: Circle not locating properly when creating 3D segment in XpresRoute in sub-assembly
PR 6772627: Zones do not work properly with Adjustable Assemblies
===Draft===
PR 1879173: Subscript text size cannot be changed via stack options
PR 1904131: The command 'Retrieve Dimensions' generates a small angular dimension
PR 1904254: Fixed a problem aligning drawing views using keypoints to blocks
PR 1904828: Solid Edge Crash when Editing Text
PR 1905667: Merge vertical cells with same value doesn't work correctly
PR 1906483: Dimension's projection lines are not shown
PR 1906525: Underlined balloons added in ST4 to ST3 ones are orientated to the wrong side
PR 2198792: Dimension disappears when "Convert to 2D View" is executed
PR 2200501: Tolerance symbol removed when dimension is dragged in AutoCAD
PR 2202087: Scale line widths should be enabled by default instead of scale line types
PR 1906788: Fixed a problem with LT format code not displaying in Callout text on scalar values
PR 1910328: Stretch command does not work on shared embed inserted symbols
PR 6767274: Clicking Back or Cancel in the Drawing View Layout step causes a crash
PR 1911446: Save As PDF - No error message when pdf file couldn't be overwritten
PR 6759715: Center justified callout jumps to the left when modified
PR-6776073: New callouts with property text don't honor the user's return/new lines
PR 1909452: Dimensions detach or incorrectly bind on update of view with PMI sections
===Part/Profile/Sheet Metal===
PR 1903647: Thread information not being present in Synchronous part copy
PR 2198575: Can´t import CATIA V5 file
PR 2199611: After adding protrusion 'Edit Definition handles' does not appear for some holes
PR 2200996: the move faces command terminating if "Ctrl+F" is used
PR 6724478: Red Pencils in PathFinder after Edit Profile with no changes
PR 6735355: Part disappears when adding a pattern of holes
PR 6747704: Not seeing the failure code during preview
PR 1907418: Solid Edge is closing when using show variability
PR 2202748: Abort when using mouse wheel to scroll through MRU
PR 1902823: Differences in Flat Pattern between ST2 and ST4
PR 1904514: Wrong visualization when suppressing an occurrence in assembly sketch pattern
===Insight===
PR 1905478: Revision Manager Set Path Browse for Folder slow performance over network on Windows 7
PR 6758938: Bend Radius change is not honored in a SharePoint managed assembly
===Solid Edge Embedded Client===
PR 1884750: Diagnostics tool is not working
PR 1902765: Error on save as translated from read-only part opened from assembly.
PR 1905070: Data preparation - Filename with accents
PR 6730948: Setting the revision and then the Item ID causes the dataset name to not display
PR 6740151: Edge crashes on saving the file to Teamcenter sub folder and then exit
PR 6748390: Query will not return TC item revisions with no SE datasets
PR 6746704: BOM Dialog display for Empty Item Revision
PR 1903302: Revise with SEEC_Image_Generate_3D=false creates JT file if already present
PR 6721338: SEEC Admin Policy files are getting delivered to the wrong location
PR 6760443: Custom Property on draft file converting from date field to text field.
PR 1902441: Save As into existing item revision doesn't work (naming rule)
PR 1899293: Non SE datasets are loaded in ST Cache during load process
PR 1907261: Assigning Rev ID before Item ID in Save As incorrectly names dataset
PR 1901182: Property manager needs hour(s) to show properties
End
http://www.facebook.com/SolidEdgeDeutschland
- Jeden Freitag: Call der Woche - der SolidEdge Helpdesk http://www.cad-helpdesk.de/sst
www.sstcad.de
