Moin Rene,
sollte so laufen allerdings gibt es keinen Parameter um explizit
Duplex anzufordern daher das Range Argument. Speichern als .VBS
Kein Error-handling eingebaut!
Option Explicit
Dim i
Dim cnt
Dim sRange
Dim mApp
Dim mDraft
Set mApp = GetObject(, "SolidEdge.Application")
' alternative (Draft/SE nicht offen)
'Set mApp = CreateObject("SolidEdge.Application")
'Call mapp.Documents.Open(" your file path ")
Set mDraft = mApp.ActiveDocument
For i = 1 To mDraft.Sections.WorkingSection.Sheets.Count
If mDraft.Sections.WorkingSection.Sheets(i).Name = "Blatt1" Or _
mDraft.Sections.WorkingSection.Sheets(i).Name = "Sheet1" Then
sRange = sRange & i & ","
cnt = cnt + 1
If cnt >= 2 Then
sRange = Left(sRange, Len(sRange) - 1)
Exit For
End If
End If
Next
If cnt > 0 Then
' PrintOut([Printer], [NumCopies], [Orientation], [PaperSize], [Scale], [PrintToFile], [OutputFileName], [PrintRange], [Sheets], [ColorAsBlack], [Collate])
Call mDraft.PrintOut("Adobe PDF",,,,,,,sRange)
Else
MsgBox "Blaetter nicht gefunden"
End If
sRange = vbNullString
cnt = 0
' Clean up
' wenn Alternative
' Call mDraft.Close(FALSE)
Set mDraft = Nothing
Set mApp = Nothing
Lieber Fehler riskieren als Initiative verhindern (R. Mohn)
[Diese Nachricht wurde von modeng am 16. Apr. 2008 editiert.]
