Thema: Pipe Utilities (1020 mal gelesen)
CSPalmer84 Mitglied Illustrator, Programmer
Beiträge: 32 Registriert: 10.12.2014 Dell T1700 3.4 Ghz 16 Gb
erstellt am: 20. Jul. 2017 17:56 <-- editieren / zitieren --> Unities abgeben:
This will probably be my last one for a while as I got new software to learn now :/ These are Pipe utilities, one is to create a pipe along the selected pipe route, and the second is for when the first one doesn't work. Generally it's needed when you merge two pipes together and the didn't merge nicely. It creates 3d lines through the selected pipe walls so you can edit them and sweep the pipe geometry on it. Also, I added a command changer as there are people who are using different versions of the software. **NOTE** You will need to load both of these files for the Pipe Utilities to work. Enjoy the movie ------------------ The sword alone does not give you the courage and strength you will need on your journey [Diese Nachricht wurde von CSPalmer84 am 21. Jul. 2017 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
StephanWörz Mitglied Maschinenbautechniker
Beiträge: 770 Registriert: 11.10.2000 CEDM V20 SolidPower V20 ModelSearch KeyShot 7 CadDoctor V4.2 SWX 2008 PHOENIX V10
erstellt am: 21. Jul. 2017 08:55 <-- editieren / zitieren --> Unities abgeben: Nur für CSPalmer84
Hello, good morning! Thanks for the code, interesting Approach! I can make good use of it. ...where is the function sd_capture_or_reactivate_user_wp defined? ------------------ ...viele Grüße Stephan Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 21. Jul. 2017 13:52 <-- editieren / zitieren --> Unities abgeben:
I thought I took that out... It's just a simple code that returns you to the previous workplane you were working off of (defvar *UsersLastWP* nil) ;;;; =================================================================================================================== (defun sd_capture_or_reactivate_user_wp (Func) ;;;; =================================================================================================================== ;;What do you want to do? (cond ;;When the module starts ((= Func 0)(setq *UsersLastWP* (sd-inq-curr-wp)) ) ;;When the module ends ((= Func 1)(sd-call-cmds(current_wp *UsersLastWP*)) ) );cond );defun ------------------ The sword alone does not give you the courage and strength you will need on your journey [Diese Nachricht wurde von CSPalmer84 am 21. Jul. 2017 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
edgar Mitglied Dipl. Ing. Maschinenbau
Beiträge: 386 Registriert: 06.06.2001 WINDOWS XP OSM 18.00A OSD 18.00A HP Z400
erstellt am: 21. Jul. 2017 14:22 <-- editieren / zitieren --> Unities abgeben: Nur für CSPalmer84
erstellt am: 21. Jul. 2017 15:37 <-- editieren / zitieren --> Unities abgeben:
you need to load the sd-defun-3d-cmd-changes.lsp file along with it. It's in a separate function because the sweep and helix commands have changed in 19, so I wanted it to be compatible with more than one version of the software. Also, take note, if you have v17 or lower, you need to update how that file finds and distinguishes the Modeling version. I've only had 18-20, so I don't have it compatible with anything lower than that. ------------------ The sword alone does not give you the courage and strength you will need on your journey [Diese Nachricht wurde von CSPalmer84 am 21. Jul. 2017 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
