These functions are used to create Imperial threaded Bolts Nuts and Washers. Granted, they aren't very detailed, but its still easier then drawing them manually. I also provided a "simple" PDM chart...... it's based on what we used here since we don't use PTC's pdm, so please take it with a grain of salt. Also please note that you need to load sd-machine-fasteners.lsp and sd-machine-threads.lsp for these to work; by default the PDM I made is disabled. The initial selection of 'Select Face' and 'Center Point' are optional, but they're used to move part into position. One last note, the double sided stud has an illustration picture for its dialog.
The sword alone does not give you the courage and strength you will need on your journey
[Diese Nachricht wurde von CSPalmer84 am 17. Jul. 2017 editiert.]
