  PTC Creo Elements/Direct Modeling
  Workmanager 5.15 and OSD 11.65
Autor Thema:  Workmanager 5.15 and OSD 11.65 (548 mal gelesen)
rene.weimar
CAD engineer
Sehen Sie sich das Profil von rene.weimar an!   Senden Sie eine Private Message an rene.weimar  Schreiben Sie einen Gästebucheintrag für rene.weimar
erstellt am: 05. Jun. 2003 12:28    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello,
I have used Workmanager 5.15 with OSD 11.60. All works well. Now I have installed OSD 11.65. When I try to load a drawing from Workmanager I get nothing. (see picture) The drawing does load from OSD in designer mode or when I execute the macro Awmc_amsd_m_load_dwg 0 "BA90UC7FHXUJUP" "BCH17263HXUJUP" in workmanager.
The problem is that the macro doesnot see that Annatations is running. (See trace60 from OSD 11.60 and trace 65 for 11.65)
In trace60 the command "LET Anno_active ( DDE_REQUEST Dde_handle 6160534 "Annotation_active" )" returns "1" which means Annotations is running. It then runs the macro "Awmc_amsd_m_load_dwg ....." and the drawing is loaded into Annotations.
In trace65 the command "LET Anno_active ( DDE_REQUEST Dde_handle 2753388 "Annotation_active" )" returns "0" which means Annotations is not running (But it is!!!) It then runs the macro
"Awmc_me10_m_load_dwg" and thus tries to load the drawing into ME10.
Does anyone know how to repair this?
Sincerely
René Weimar
rene.weimar
CAD engineer
erstellt am: 05. Jun. 2003 14:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
trace60.txt
trace65.txt
I hope the trace files are now present.
rene.weimar
CAD engineer
erstellt am: 05. Jun. 2003 16:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello,
I looked further into the problem. I see that the request that Workmanager does is not answered correctly.
(setq intChan1 (sd-dde-initiate "ME10F" "GENERAL"))
(sd-dde-request intChan1 "Annotation_active")
I simulated with the above code if Annotations is active in OSD. It appears that in 11.60 the request returns 1 (Active) but in 11.65 it returns 0 (Inactive)
Hope someone knows how to manipulate the answer Workmanager gets.
Architekt/ Bauingenieur (m/w/d) für Ladeinfrastruktur/Elektromobilität
Die BayWa Mobility Solutions GmbH konzentriert sich auf Angebote rund um eine CO2-optimierte Mobilität. Unser Schwerpunkt liegt in der Planung und dem Aufbau von Ladehubs (Ladeparks) und ganzheitlichen Ladeinfrastruktursystemen inkl. Abrechnung, Wartung und Energiemanagement. Die BayWa Mobility Solution GmbH ist eine Tochter des weltweit tätigen BayWa Konzerns mit den Segmenten Agrar, Energie und Bau sowie Innovation und Digitalisierung....
Anzeige ansehenArchitektur
woho
Technik CAD
Sehen Sie sich das Profil von woho an!   Senden Sie eine Private Message an woho  Schreiben Sie einen Gästebucheintrag für woho
von SolidDesigner ab 1.0
ueber Precision Engineering Dynamic Modeling
ueber CoCreate Modeling
bis Creo Elements/Direct 20.x
erstellt am: 06. Jun. 2003 08:11    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für rene.weimar 10 Unities + Antwort hilfreich
Hi René,
WorkManager 5.15 and OSD 11.65 is not supported.
The best solution is to update WorkManager.
It is a lot of work - I know, but otherwise it is possible
to get more and more problems with WorkManager.
It worked with OSD 11.6 - it was not supported too.
Perhaps you had luck.
Regards
WoHo
