Hallo Svener,
erst mal herzlich Willkommen im cad.de Forum! Ich hab mal in der Knowledge Datenbank von Autodesk nachgeschaut und bin auf folgendes gestossen:
"Error: Autodesk MapGuide Viewer ActiveX Control requires Microsoft Internet Explorer 5.0 or higher
Published date: 2001-11-05
Applies to:
Autodesk MapGuide® 6
Issue
When you attempt to install Autodesk MapGuide® Viewer 6 software on Microsoft® Internet Explorer 6, the following error occurs:
Autodesk MapGuide Viewer ActiveX Control requires Microsoft Internet Explorer 5.0 or higher.
Solution
Autodesk MapGuide 6 is not officially supported for use with Microsoft Internet Explorer 6. Due to the proximity of release dates for Autodesk MapGuide 6 and Internet Explorer 6, testing of the various Autodesk MapGuide clients in this environments did not occur.
To resolve this problem, you need to:
Uninstall Internet Explorer 6 (restoring the previous version of Internet Explorer).
Install Autodesk MapGuide 6 Viewer.
Reinstall Internet Explorer 6.
Use the following procedure:
On the Start menu (Windows), click Settings > Control Panel.
Open Add/Remove Programs and click the Change/Remove button for Microsoft Internet Explorer 6.
Select Restore the previous Windows configuration and click OK.
Selecting this option restores Internet Explorer to version 5.x.
Install Internet Explorer 6.
Leider findet man in der Knowledge Datenbank relativ viele Fehler in Verbindung Internet Explorer 6 und Map Guide 6.
Heike
