Moin, ja die Routine benötigt alle Polygonpunkte als Array. Sie berechnet ja die Fläche nach Gauß
Lieben Gruß
Function POINTS_FROM_ENTITY(ByRef POINTS() As Point3d, entity As AcadEntity, Optional center As Boolean = True, Optional infohandle As Boolean = True, Optional SUBARCDIVIDER As Long = 0) As Long
Dim TTEXT As ACADTEXT
Dim MTEXT As AcadMText
Dim acircle As AcadCircle
Dim aarc As AcadArc
Dim face As Object
Dim ppoint As AcadPoint
Dim spline As AcadSpline
Dim BLOCKREF As AcadBlockReference
Dim v As Variant
Dim p As Point3d
Dim PP() As Point3d
Dim S As String
Dim linefound As Boolean
Dim N As Long
Dim radius As Double
If entity Is Nothing Then Exit Function
POINTS_FROM_ENTITY = 0
''debug.print entity.objectname
Dim Lastpoints As Long
On Error Resume Next
newpointstart = UBound(POINTS)
On Error GoTo 0
Select Case LCase(entity.objectname)
Case "acdbtext"
Set TTEXT = entity
v = TTEXT.insertionPoint
p = V2P3D(v)
S = TTEXT.TEXTSTRING
S = REPLACE(S, ",", ".")
If Len(S) > 4 Then
If p.z = 0 And IsNumeric(S) = True Then p.z = val(S)
p.INFO = S
Call POINTS_ADD_3D(POINTS(), p)
N = N + 1
Else
entity.COLOR = acYellow
End If
Case "acdbmtext"
Set MTEXT = entity
v = MTEXT.insertionPoint
p = V2P3D(v)
S = MTEXT.TEXTSTRING
p.INFO = S
N = N + 1
Case "acdbpoint"
Set ppoint = entity
v = ppoint.COORDINATES
p = V2P3D(v)
N = N + 1
Case "acdbcircle"
Set acircle = entity
v = acircle.center
p = V2P3D(v)
N = N + 1
Case "acdface", "aeccdbface", "acdbface"
Set face = entity
If face_get_POINTs(POINTS, entity) Then
N = N + UBound(POINTS)
End If
Case "acdbhatch"
'Debug.Print "points from hatch is not supported"
Case "acdbarc"
Set aarc = entity
v = aarc.center
MP = aarc.center
radius = aarc.radius
Dim M As Point3d
M.X = aarc.center(0)
M.y = aarc.center(1)
M.z = aarc.center(2)
Dim RP As Point3d
Dim a As Double
Dim aa As Double
If KP = 0 Then KP = SUBARCDIVIDER + 1
If KP = 0 Then KP = ARCDIVIDER + 1
If KP = 0 Then KP = 3
a = (aarc.endAngle - aarc.startAngle) / KP
' Debug.Print R2D(aarc.endAngle), R2D(aarc.startAngle), R2D(aarc.endAngle - aarc.startAngle), R2D(A)
aa = aarc.startAngle
Dim sp As Point3d
sp.X = aarc.startPoint(0)
sp.y = aarc.startPoint(1)
X = sp.X - M.X
y = sp.y - M.y
r = aarc.radius
Dim aaa As Double
aa = aarc.startAngle - a
For i = 0 To KP
aa = aa + a
Debug.Print
RP.X = 0
RP.y = 0
RP.X = r * Cos(aa) + M.X '- Y * sIn(aa)
RP.y = r * sin(aa) + M.y '+ Y * Cos(aa)
' RP.X = RP.X * Cos(aaa) - RP.Y * sIn(aaa)
' RP.Y = RP.X * sIn(aaa) + RP.Y * Cos(aaa)
RP.z = aarc.center(2)
'Call DBGBALLP3D(RP)
Call POINTS_ADD_3D(POINTS(), RP)
Next
N = KP
If 1 = 2 Then
KILLBALL
Dim PSP As Point3d
PSP.X = v(0)
PSP.y = v(1)
PSP.z = v(2)
Call DBGBALLP3D(PSP)
Dim PHI(1) As Double
Dim theta(1) As Double
Dim AT As Double
AT = aarc.TotalAngle
Dim pt As Point3d
'sphere parametric form
'x = xc + r * cos(theta) * cos(phi)
'y = yc + r * cos(theta) * sin(phi)
'z = zc + r * sin(theta)
Dim ctheta As Double
For i = 0 To 1
theta(i) = ArcSin((PP(i).z - PSP.z) / radius)
ctheta = Cos(theta(i))
If ctheta > 0 Then
PHI(i) = ArcSin((PP(i).y - PSP.y) / radius / ctheta)
PHI(i) = ArcCos((PP(i).X - PSP.X) / radius / ctheta)
End If
'debug.print PHI(I) * 180 / Pi, Theta(I) * 180 / Pi
pt.X = PSP.X + radius * Cos(theta(i)) * Cos(PHI(i))
pt.y = PSP.y + radius * Cos(theta(i)) * sin(PHI(i))
pt.z = PSP.z + radius * sin(theta(i))
Call DBGBALLP3D(pt)
Next
applicaTION.UPDATE
'debug.print (PHI(1) - PHI(0)) * 180 / Pi, (Theta(1) - Theta(0)) * 180 / Pi
Dim PN As Point3d
Dim THETATOTAL As Double
Dim PHITOTAL As Double
PHITOTAL = PHI(1) - PHI(0)
THETATOTAL = theta(1) - theta(0)
Dim pphi As Double
Dim ptheta As Double
Dim DP As Double
Dim dt As Double
ReDim PP(N)
N = 6
pphi = PHITOTAL / (N)
ptheta = THETATOTAL / (N)
DP = PHI(0)
dt = theta(0)
For i = 0 To N
'debug.print Sin(DT)
pt.X = PSP.X + radius * Cos(dt) * Cos(DP)
pt.y = PSP.y + radius * Cos(dt) * sin(DP)
pt.z = PSP.z + Sqr(radius * radius - ((radius * Cos(dt) * Cos(DP)) ^ 2 + (radius * Cos(dt) * sin(DP)) ^ 2))
'r2 = X2 + Y2 + z2
'PT.z = PSP.z + RADIUS * Sin(dt)
DP = DP + pphi
dt = dt + ptheta
Call DBGBALLP3D(pt)
Call POINTS_ADD_3D(POINTS(), pt)
Next
End If
Case "acdbblockreference"
Set BLOCKREF = entity
v = BLOCKREF.insertionPoint
p = V2P3D(v)
N = N + 1
' Case "acdbsection"
Case Else
linefound = False
If (InStr(LCase(entity.objectname), "line") > 0) And (InStr(LCase(entity.objectname), "xline") = 0) Then linefound = True
If (InStr(LCase(entity.objectname), "lead") > 0) Then linefound = True
If (InStr(LCase(entity.objectname), "face") > 0) Then linefound = True
If (InStr(LCase(entity.objectname), "section") > 0) Then linefound = True
If linefound Then
N = N + POINTS_FROM_POLYLINE(PP(), entity)
If N > 0 Then
For i = LBound(PP) To UBound(PP)
Call POINTS_ADD_3D(POINTS(), PP(i))
Next
End If
End If
If InStr(LCase(entity.objectname), "xline") > 0 Then
Dim xl As AcadXline
Set xl = entity
ReDim POINTS(1)
N = 2
POINTS(0).X = xl.basePoint(0)
POINTS(0).y = xl.basePoint(1)
POINTS(0).z = xl.basePoint(2)
POINTS(1).X = xl.DirectionVector(0) + POINTS(0).X
POINTS(1).y = xl.DirectionVector(1) + POINTS(0).y
POINTS(1).z = xl.DirectionVector(2) + POINTS(0).z
End If
End Select
If N <> 0 Then
If infohandle = True Then
For i = Lastpoints + 1 To UBound(POINTS)
POINTS(i).INFO = entity.HANDLE
Next
End If
End If
POINTS_FROM_ENTITY = N
End Function
Function POINTS_FROM_POLYLINE(ByRef POINTS() As Point3d, entity As AcadEntity) As Long
Dim v As Variant
Dim i As Long
Dim j As Long
Dim POINTCOUNT As Long
Dim polylw As AcadLWPolyline
Dim POLY3D As Acad3DPolyline
Dim Poly2D As AcadLWPolyline
Dim polym As AcadMLine
Dim polyAC As AcadPolyline
Dim line As acadline
Dim LEADER As AcadLeader
Dim MLEADER As ACADOBJECT 'AcadMleader
Dim face As Acad3DFace
Dim closed As Boolean
Dim S As String
DoEvents
POINTS_FROM_POLYLINE = -1
S = LCase(entity.objectname)
j = 0
closed = False
Select Case S
Case "acdbline"
Set line = entity
ReDim POINTS(1)
POINTS(0).X = line.startPoint(0)
POINTS(0).y = line.startPoint(1)
POINTS(0).z = line.startPoint(2)
POINTS(1).X = line.endPoint(0)
POINTS(1).y = line.endPoint(1)
POINTS(1).z = line.endPoint(2)
POINTCOUNT = 1
Case "acdbpolyline"
v = entity.COORDINATES
POINTCOUNT = ((UBound(v) + 1) / 2) - 1
Erase POINTS
ReDim POINTS(POINTCOUNT)
''debug.print pointcount
Set polylw = entity
closed = polylw.closed
For i = 0 To POINTCOUNT
POINTS(i).X = v(j): j = j + 1
POINTS(i).y = v(j): j = j + 1
POINTS(i).z = polylw.ELEVATION
POINTS(i).B = polylw.GetBulge(i)
'POINTS(i).z = polylw.COORDINATES(j): j = j + 1
' points(i).z = polyLW.coordinates(J): J = J + 1
Next
Case "acdb3dpolyline"
Set Acad3DPolyline = entity
closed = Acad3DPolyline.closed
' pointCount = ((UBound(v) + 1) / 2) - 1
POINTCOUNT = ((UBound(v) + 1) / 3) - 1
POINTS(i).z = v(j): j = j + 1
POINTS(i).B = 0
Next
POINTS_FROM_POLYLINE = POINTCOUNT
Case "acdbface"
Set face = entity
closed = False
v = face.COORDINATES
POINTS(i).X = face.COORDINATES(j): j = j + 1
POINTS(i).y = face.COORDINATES(j): j = j + 1
POINTS(i).z = face.COORDINATES(j): j = j + 1
Next
Case "acdblwpolyline"
Set polylw = entity
v = polylw.COORDINATES
Next
Case "acdb2dpolyline"
Set polyAC = entity
closed = polyAC.closed
POINTS(i).B = polyAC.GetBulge(i)
POINTS(i).z = polyAC.ELEVATION
Next
Case "acdbmline"
Set polym = entity
Next
Case "acdbleader"
'Set leader = entity
Next
Case "_acdbmleader"
Dim MLEAD As AcadMleader
Set MLEAD = entity
'V = MLEAD.COORDINATES
Next
Set POLY3D = entity
closed = POLY3D.closed
v = POLY3D.COORDINATES
Next
Case "acdbspline"
Set spline = entity
spline.SplineMethod = acFit
v = spline.fitPoints
Next
Case "acdbsection"
Dim SECT As AcadSection
Set SECT = entity
closed = False
POINTCOUNT = SECT.NumVertices - 1
v = SECT.coordinate(i)
POINTS(i).X = v(0)
POINTS(i).y = v(1)
POINTS(i).z = v(2)
Next
closed = False
End Select
If closed Then
POINTCOUNT = POINTCOUNT + 1
ReDim Preserve POINTS(POINTCOUNT)
POINTS(POINTCOUNT) = POINTS(0)
End If
POINTS_FROM_POLYLINE = POINTCOUNT + 1
End Function
Sub POINTS_add(POINTS() As Point3d, ByVal X As Double, ByVal y As Double, Optional ByVal z As Double = 0, Optional INFO As String, Optional BULGE As Double)
Dim C As Long
ERR.CLEAR
ubtest = UBound(POINTS)
If ERR.NUMBER <> 0 Then
ReDim POINTS(0)
Else
C = UBound(POINTS) + 1
End If
If POINTS(0).X <> NAN Then
ReDim Preserve POINTS(0 To C)
POINTS(C).X = X
POINTS(C).y = y
POINTS(C).z = z
POINTS(C).INFO = INFO
POINTS(C).B = BULGE
Else
POINTS(0).X = X
POINTS(0).y = y
POINTS(0).z = z
POINTS(0).B = BULGE
End If
End Sub
Wer es nicht versucht, hat schon verlorn
Und bei 3 Typos gibts den vierten gratis !
<<< not for sale !
