Code:
Option Explicit
'---Winkelfunktion definieren-----------------------------------------------------
Const pi = 3.14159
'---Winkelfunktion definieren------------------------------------------------------
Function dtr(a As Double) As Double
dtr = (a / 180) * pi
End Function
Public Sub Stellfuss01()Dim cP(0 To 2) As Double
cP(0) = 0#: cP(1) = 0#: cP(2) = 0#
Dim StBlock As AcadBlock
Dim col1 As New AcadAcCmColor
Call col1.SetRGB(59, 59, 59)
Dim col2 As New AcadAcCmColor
Call col2.SetRGB(245, 245, 248)
On Error Resume Next
Set StBlock = ThisDrawing.Blocks("test02")
If Err.Number = 0 Then
'Block schon vorhanden
Exit Sub
End If
On Error GoTo 0
Set StBlock = ThisDrawing.Blocks.Add(cP, "test02")
Dim StLay As AcadLayer
Set StLay = ThisDrawing.Layers.Add("Stellfuss1")
Dim S1, S2, S3, S4, S5, S6 As Variant
Dim stellobj1(0 To 4) As AcadEntity
With ThisDrawing.Utility
S1 = .PolarPoint(cP, dtr(180#), 21)
S2 = .PolarPoint(S1, dtr(180#), 1.5)
S3 = .PolarPoint(S2, dtr(90#), 1.5)
S4 = .PolarPoint(S3, dtr(90#), 12.5)
S5 = .PolarPoint(S4, dtr(0#), 14)
S6 = .PolarPoint(S5, dtr(0#), 8.5)
End With
With ThisDrawing.ModelSpace
Set stellobj1(0) = .AddLine(cP, S1)
Set stellobj1(1) = .AddLine(S1, S3)
Set stellobj1(2) = .AddLine(S3, S5)
Set stellobj1(3) = .AddLine(S5, S6)
Set stellobj1(4) = .AddLine(S6, cP)
End With
Dim regobj1 As Variant
regobj1 = ThisDrawing.ModelSpace.AddRegion(stellobj1)
Dim axisDir(0 To 2) As Double
Dim angle As Double
axisDir(0) = 0.001: axisDir(1) = 360: axisDir(2) = 0
angle = (2 * pi)
Dim solidObj0 As Acad3DSolid
'Set solidObj0 = ThisDrawing.ModelSpace.AddRevolvedSolid(regobj1(0), cP, axisDir, angle)
Set solidObj0 = StBlock.AddRevolvedSolid(regobj1(0), cP, axisDir, angle)
solidObj0.TrueColor = col1
solidObj0.Layer = "Stellfuss1"
Dim rota As Double
rota = (pi * 7.5)
solidObj0.Rotate3D cP, S1, rota
stellobj1(0).Delete
stellobj1(1).Delete
stellobj1(2).Delete
stellobj1(3).Delete
stellobj1(4).Delete
regobj1(0).Erase
Dim G0, G1, G2, G3, G4, G5 As Variant
Dim gewiobj1(0 To 4) As AcadEntity
G0 = .PolarPoint(S6, dtr(90#), 6)
G1 = .PolarPoint(G0, dtr(180#), 5)
G2 = .PolarPoint(G1, dtr(90#), 43)
G3 = .PolarPoint(G2, dtr(90#), 2)
G4 = .PolarPoint(G3, dtr(0#), 2)
G5 = .PolarPoint(G4, dtr(0#), 3)
End With
Set gewiobj1(0) = .AddLine(G0, G1)
Set gewiobj1(1) = .AddLine(G1, G2)
Set gewiobj1(2) = .AddLine(G2, G4)
Set gewiobj1(3) = .AddLine(G4, G5)
Set gewiobj1(4) = .AddLine(G5, G0)
End With
Dim gewreg As Variant
gewreg = ThisDrawing.ModelSpace.AddRegion(gewiobj1)
Dim axisDir1(0 To 2) As Double
Dim angle1 As Double
axisDir1(0) = 0.01: axisDir1(1) = 360: axisDir1(2) = 0
angle1 = (2 * pi)
Dim gewObj As Acad3DSolid
'Set gewObj = ThisDrawing.ModelSpace.AddRevolvedSolid(gewreg(0), cP, axisDir1, angle1)
Set gewObj = StBlock.AddRevolvedSolid(gewreg(0), cP, axisDir1, angle1)
gewObj.TrueColor = col2
gewObj.Layer = "Stellfuss1"
gewObj.Rotate3D cP, S1, rota
gewiobj1(0).Delete
gewiobj1(1).Delete
gewiobj1(2).Delete
gewiobj1(3).Delete
gewiobj1(4).Delete
gewreg(0).Erase
Dim usObj As Acad3DSolid
Dim radius As Double
Dim height As Double
radius = 8#
height = 1#
'Set usObj = ThisDrawing.ModelSpace.AddCylinder(cP, radius, height)
Set usObj = StBlock.AddCylinder(cP, radius, height)
Dim U0#(2), U1#(2)
U1(2) = U0(2) + 14.5
usObj.Move U0, U1
usObj.TrueColor = col2
usObj.Layer = "Stellfuss1"
Dim M0, M1, M2, M3, M4, M5, M6, M7, M8, M9, M10 As Variant
Dim muobj1(0 To 5) As AcadEntity
M0 = .PolarPoint(cP, dtr(270#), 7.0002)
M1 = .PolarPoint(M0, dtr(180#), 4.0416)
M2 = .PolarPoint(M1, dtr(180#), 4.0416)
M3 = .PolarPoint(M2, dtr(90#), 7.002)
M4 = .PolarPoint(M3, dtr(90#), 7.002)
M5 = .PolarPoint(M4, dtr(0#), 4.0416)
M6 = .PolarPoint(M5, dtr(0#), 8.0831)
M7 = .PolarPoint(M6, dtr(0#), 4.0416)
M8 = .PolarPoint(M7, dtr(270#), 7.002)
M9 = .PolarPoint(M8, dtr(270#), 7.002)
M10 = .PolarPoint(M9, dtr(180#), 4.0416)
End With
Set muobj1(0) = .AddLine(M1, M3)
Set muobj1(1) = .AddLine(M3, M5)
Set muobj1(2) = .AddLine(M5, M6)
Set muobj1(3) = .AddLine(M6, M8)
Set muobj1(4) = .AddLine(M8, M10)
Set muobj1(5) = .AddLine(M10, M1)
End With
Dim mureg As Variant
mureg = ThisDrawing.ModelSpace.AddRegion(muobj1)
Dim taperAngle As Double
taperAngle = 0
Dim mutter As Acad3DSolid
'Set mutter = ThisDrawing.ModelSpace.AddExtrudedSolid(mureg(0), 6, taperAngle)
Set mutter = StBlock.AddExtrudedSolid(mureg(0), 6, taperAngle)
Dim MU0#(2), MU1#(2)
MU1(2) = MU0(2) + 15
mutter.Move MU0, MU1
mutter.TrueColor = col2
mutter.Layer = "Stellfuss1"
muobj1(0).Delete
muobj1(1).Delete
muobj1(2).Delete
muobj1(3).Delete
muobj1(4).Delete
muobj1(5).Delete
mureg(0).Erase
End Sub
