Hallo allesamt,
ich habe eine (hoffentlich kleine) Frage an euch:
In der SolidWorks API-Hilfe habe ich ein Beispiel für das anlegen von virtuellen Teilen in einer Baugruppe und anschließendes speichern als existierende Datei gefunden.
' Preconditions:
' 1. Open: <SolidWorks_install_dir>\samples\tutorial\smartcomponents\stepped_shaft.sldasm
' 2. A planar face on the assembly is selected.
' 3. Step through this macro (F8).
' Postconditions:
' 1. The new part is inserted as a virtual component in the assembly.
' 2. The virtual component is saved to an external file,
' and its name changes in the FeatureManager design tree.
' NOTE: Because this assembly is used in a SolidWorks online tutorial, do not
' save the assembly when you close it.
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swAssy As SldWorks.AssemblyDoc
Dim swComponent As SldWorks.Component2
Dim swSelMgr As SldWorks.SelectionMgr
Dim status As Long
Sub Main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
' Get the pre-selected planar face
Dim swFeature As SldWorks.Face2
Set swSelMgr = swModel.SelectionManager
Set swFeature = swSelMgr.GetSelectedObject6(1, 0)
' Create the part and insert it as a virtual component
' in the assembly
status = swAssy.InsertNewVirtualPart(swFeature, swComponent)
If status = 1 Then
Debug.Print "Name of virtual component: " & swComponent.Name2
' Check to see if the part is a virtual component
Debug.Print "Is component virtual? " & swComponent.IsVirtual
Dim objFSO As Object
Dim objFile As Object
Dim compName As String
Dim splits As Variant
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.GetFile(swModel.GetPathName)
splits = Split(swComponent.Name, "^")
compName = objFSO.GetParentFolderName(objFile) & "\" & splits(0)
If swComponent.GetModelDoc2.GetType = swDocPART Then
compName = compName & ".sldprt"
Else
compName = compName & ".sldasm"
End If
Debug.Print "Name of saved virtual component: " & compName
swComponent.SaveVirtualComponent compName
Else
Debug.Print "Error code returned when attempting to insert new part as virtual component: " & status
End If
swModel.ClearSelection2 (True)
End Sub
Jetzt zu meiner eigentlichen Frage:
In den Preconditions ist ja schon erwähnt, dass eine plane Fläche von einem existierenden Teil angewählt sein muss um das Makro zu starten. Geht das ganze aber auch wenn ich nur eine Ebene ausgewählt habe (Beispiele: "Ebene Vorne")? Und wenn ja, wie? Hab schon ein bisschen rumprobiert aber nichts klappt.
Danke im Voraus für eure Hilfe
