Hot News aus dem CAD.de-Newsletter:
  Colour is Back in SWX2016 SP3
Autor Thema:   Colour is Back in SWX2016 SP3 (3176 mal gelesen)
ublum
Dipl.Ing.(FH) Kunststofftechnik
Sehen Sie sich das Profil von ublum an!   Senden Sie eine Private Message an ublum  Schreiben Sie einen Gästebucheintrag für ublum
Wer Gutes tut, tut es für seine eigene Seele. Wer Unrecht begeht, begeht es gegen sich selbst.
SolidWorks2016
AutoCad2016
DDS2016
erstellt am: 14. Jan. 2016 10:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Anbei ein Auszug aus dem Forum von Tom Spine, dieser ist zuständig für die UI in Solidworks
[URL=https://forum.solidworks.com/thread/107846?start=150&tstart=0][/URL]
Hi Everyone,
We wanted to give you a few more details on what is planned and on the timing.
Code changes for SOLIDWORKS 2016 SP02 were locked down at the end of December and SP2 EV (Early Visibility) is planned for next week as we finish up final stability testing. SP2 contains over 200 customer-driven and stability fixes, so we need to stay on schedule with that as we continue to work on your important UI concerns.
Among other things, 2016 SP2 includes:
• - Text contrast in the FeatureManager design tree: This issue is related to text color becoming gray instead of black when switching the Interface brightness setting. In
•    SP0 and SP01, you can work around this problem by going to Tools, Options, System Options, Colors, Color Scheme Settings, and setting the FeatureManager Design
•    Tree color to black. The issue is fixed in SP2.
• - Mate icons: A fix for an issue where assembly mate icons are not greyed out when an assembly part is suppressed.
• - Other fixes: About 25 fixes for issues related to the user interface brightness settings, most about problems with the Dark theme.
But for much of your feedback, SP3 is the release target. For 2016 SP3, we are on track for:
• - Color icons:  An option will be added to provide more colorful icons, as so many of you are asking for. The icons representing the most frequent and visible modeling
•   features (solids, surfaces, sheet metal, weldments) will be recolored to match the 2015 color scheme.
• - Background color: As with the color icons, there will be an option for a background color that closely matches 2015.
• - Hide/Show/Suppress states in the FeatureManager design tree:  We will address the issues regarding the Hide/Show/Suppress state distinction in the
•   FeatureManager design tree by using a similar approach to SOLIDWORKS 2015. The change will include using “wireframe” icons for hidden state and improving the
•   coloring of some of the current SOLIDWORKS 2016 icons so suppressed icons are more distinguishable (for example making the part, folder, and solid body icons blue
•   instead of gray).
We are also working on the issue about the sketch icon (crosshair versus pencil). If we can get this addressed in SP3, we will.
2016 SP3 is currently scheduled to be in Early Visibility in mid-March and to go live in early April. We hope that users will sign up for and use SP3 EV since it will be the first “live” access to these changes. For more information and to sign up for early visibility, go here: https://www.solidworks.com/sw/support/EarlyVisibility.html
We encourage you to continue the constructive feedback on the forums and we will continue to listen, reach out for feedback, and give you periodic updates.
--Tom
Grüße von der Saar
Uwe Blum
[Diese Nachricht wurde von ublum am 14. Jan. 2016 editiert.]
rawo
technische Zeichnerin
Sehen Sie sich das Profil von rawo an!   Senden Sie eine Private Message an rawo  Schreiben Sie einen Gästebucheintrag für rawo
Nichtstun macht nur Spass, wenn man eigentlich viel zu tun hätte. (Sir Coward)<P>Status: "Konfigurations-Junkie"
erstellt am: 14. Jan. 2016 11:35    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
na guck mal.... geht doch...
**Kein Mensch ist so beschäftigt, dass er nicht die Zeit hätte, jedem zu erzählen, wie beschäftig er ist.**
SWX 2015 SP5 / DBWorks R15 SP 2.5
Office 2010
Windows 10 Pro 64 bit
Dell Precision T3600
Intel Xeon E5
16 Gb RAM
NVIDIA Quadro 2000
Space Pilot Pro
Johannes Anacker
Leiter Produktmarketing
Sehen Sie sich das Profil von Johannes Anacker an!   Senden Sie eine Private Message an Johannes Anacker  Schreiben Sie einen Gästebucheintrag für Johannes Anacker
SOLIDWORKS 2016 Premium mit allen SWX-Addons mit Windows 7 auf DELL Precision M6600
erstellt am: 14. Jan. 2016 11:40    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Uwe, ich wollt schon den Hörer in die Hand nehmen und dich anrufen
Johannes Anacker
SolidLine AG
SolidLine AG bei Facebook
Soundfan
Maschinenbautechniker
Sehen Sie sich das Profil von Soundfan an!   Senden Sie eine Private Message an Soundfan  Schreiben Sie einen Gästebucheintrag für Soundfan
erstellt am: 14. Jan. 2016 11:59    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Genial!
......läuft......
Hat Die Rückmeldung vieler Kunden doch etwas bewirkt
THSEFA
Konstrukteur / CAD-Administrator
Sehen Sie sich das Profil von THSEFA an!   Senden Sie eine Private Message an THSEFA  Schreiben Sie einen Gästebucheintrag für THSEFA
SWX 2015 SP3.0
Windows 7 Prof. 64Bit
Fujitsu CELSIUS M720
Intel XEON E5 1620
Quadro 4000
16 GB Ram
erstellt am: 14. Jan. 2016 12:07    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
...stetig Tropfen höhlt den Stein...
Viele Grüße, THSEFA
"Nichts ist so hart wie das Leben! Wenn man sagt, was man denkt, muss man mehr als alles geben!..."
Thisoft
Sehen Sie sich das Profil von Thisoft an!   Senden Sie eine Private Message an Thisoft  Schreiben Sie einen Gästebucheintrag für Thisoft
SWX 2017 Standard SP 0
Win10 Professional 64Bit
Intel Core i7 920
16 GB RAM
NVIDIA Quadro FX 3800
=Beruf
SW 2017 Standard SP0
AMD Phenom II X2 550
7GB RAM
ATI Radeon HD 4600
=Privat
erstellt am: 14. Jan. 2016 12:25    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Na das sind doch mal gute Neuigkeiten. Schau'n wir mal wie das dann aussieht.
Dann ist ja jetzt nur noch 3 Monate warten auf Weihnachten angesagt
Gruß Thilo
Heiko Soehnholz
Dipl.-Ing. Maschinenbau
SOLIDWORKS seit 2001
CSWS-TSO/MD/TMD -16/17
CSWS-C/D/I/MBD/VIS -16/17
CSWP-Core/DT/MT/SM/SU/WD
CSWE CSSP CSPP CSWI
SOLIDWORKS Prem 2017SP2.0
Simulation, Composer, MBD,
Inspection, PDM Prof.,
Visualize Prof.,
TopsWorks, TableAddIn etc.
WIN10 x64 auf HP ZBook 17 G3
erstellt am: 14. Jan. 2016 13:27    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Danke fürs (Mit)Teilen dieser guten Nachricht!
Einen schönen Gruß von Heiko
- www.dps-software.de - www.iknow-solidworks.de -
ThoMay
SWX 2015
Windows 7 x64
erstellt am: 14. Jan. 2016 19:40    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Da gibts ein leises
Hallelujah
Nach dem ersten Gebrauch werden wir uns vielleicht sagen:
I'm feeling goo. Is a new dawn. Is a new day..
ThoMay
Hast du Fragen?
Brauchst du
Schaut mal nach im Bereich
oder
Richtig fragen -
Nettiquette - Konstruktionshilfen - Systeminfo - Unities - CAD Freeware - Forenübersicht - 3D Modelle - SolidWorks Videos
Torsten Niemeier
Maschinenbau Ingenieur
** CSWP 04/2011 **
** CSWE 08/2011 **
erstellt am: 14. Jan. 2016 19:43    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Leonard Cohen:
„Es ist ein guter Song, aber er wird von zu vielen Leuten gesungen.“
CAD-SUPPORTER
Standard in 3D
Sehen Sie sich das Profil von CAD-SUPPORTER an!   Senden Sie eine Private Message an CAD-SUPPORTER  Schreiben Sie einen Gästebucheintrag für CAD-SUPPORTER
WIN7 x64 + WIN10
SOLIDWORKS 2001 bis 2017
Autodesk AutoSchreibtisch Inventor 2013-2017
ATC Trainer A.D.
Solid Edge Kante V20 und ST5 - ST8
erstellt am: 14. Jan. 2016 20:47    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Wo bleibt der Gefällt mir Knopf fürs Forum?
The World is changing, the CAD World too
ThoMay
SWX 2015
Windows 7 x64
erstellt am: 14. Jan. 2016 21:02    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Hallo CAD Supporter.
Wie wäre es damit =========>
ThoMay
Hast du Fragen?
Brauchst du
oder
Richtig fragen -
CAD-SUPPORTER
Standard in 3D
WIN7 x64 + WIN10
ATC Trainer A.D.
erstellt am: 14. Jan. 2016 22:29    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Hallo ThoMay,
Erledigt, Punkte verteilt.
StefanBerlitz
Guter-Geist-Moderator
IT Admin (CAx)
SunZu sagt:
Analysiere die Vorteile, die
Dann gliedere deine Kräfte
entsprechend und mache dir
erstellt am: 15. Jan. 2016 08:56    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Original erstellt von Soundfan:
Und ich glaube gerade in diesem Fall sieht man auch, wie sehr das "viele" dabei wert ist
Ich bin mal auf die Anpassungen gespannt und könnte mir vorstellen, dass da auch ein Aufseufzen durch die Phalanx der vielen Supporter gegangen ist, die in den letzten Wochen und Monaten die Änderung des Userinterfaces als wertvolle Neuerung verteidigt haben und jetzt zumindest eine zukünftige Option anbieten können (  Jo, Heiko, Andi )
Ciao,
Stefan
Christian_W
Konstrukteur (Dipl-Ing)
(SWX 2016)
SWX 2012sp5 WIN7-64
proAlpha6.1d05/calinkV8
(Tactonworks)
(Medusa7, NesCAD2010,
solidEdge19)<P>CSWP 12/2015
erstellt am: 15. Jan. 2016 09:36    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Original erstellt von StefanBerlitz:
... die in den letzten Wochen und Monaten die Änderung des Userinterfaces als wertvolle Neuerung verteidigt haben ...
wenn sie das sehr vehement getan haben sollten, müssen sie jetzt erklären, warum es jetzt doch nicht mehr ganz so wertvoll ist ...
Schön, dass sich was tut.
Und zum "Gefällt mir - Button": damit könnte jeder sehen, dass es gefällt, nicht nur der U-Empfänger. könnte ja auch ein +/- sein, ich glaube heise-forum hatte sowas für Kommentare.
Gruß, Christian
Heiko Soehnholz
CSWE CSSP CSPP CSWI
Visualize Prof.,
erstellt am: 15. Jan. 2016 09:53    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
... und könnte mir vorstellen, dass da auch ein Aufseufzen durch die Phalanx der vielen Supporter gegangen ist, die in den letzten Wochen und Monaten die Änderung des Userinterfaces als wertvolle Neuerung verteidigt haben
Tja, da liegst du gar nicht mal so falsch. Zumal wir ja auch eine eigene Meinung haben, die sich möglicherweise mit der unserer Kunden deckt...
Es war nach-wie-vor richtig und nötig, das GUI zu überarbeiten, um eine Skalierbarkeit auf 4k-Monitoren (z. Bsp.) zu erreichen. Auch finde ich die neuen Icons überwiegend gut gelungen und stylisch (falls das wirklich wichtig sein sollte). Der Verlust an Farbe hat uns aber leider alle zu Farbenblinden gemacht, und das habe ich auch immer so geäußert. Hier haben wir unstrittig einen Verlust an Informationen und Übersichtlichkeit zu beklagen. Aber auch unabhängig von Farbe hoffe ich, dass die Darstellung von Eigenschaften wie "ausgeblendet" "unterdrückt" "transparent" nochmals überdacht und (wieder) verbessert wird.
Wir werden sehen; immerhin ist man auf dem richtigen Weg!
FBauer
Sehen Sie sich das Profil von FBauer an!   Senden Sie eine Private Message an FBauer  Schreiben Sie einen Gästebucheintrag für FBauer
NN i7 4790K @4,6GHz
8GB Ram
Quadro FX 1800
WIN10 PRO 64bit
SWX2015 PRO SP5.0
SWX2016 PRO SP5.0
3D Connexion Space Pilot<P>Lenovo i7 3770K
Quadro FX 1700
WIN10 PRO 64bit
SWX2016 PRO SP5.0
erstellt am: 15. Jan. 2016 09:55    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Ich begrüße die Entwicklung auch - und ich hätte nicht gedacht, dass die Macher das so schnell umsetzen werden.
Als ich das Präsentationsvideo https://www.youtube.com/watch?v=s35oibqYMSo angesehen habe, dachte ich noch "Wenn die Macher 25 Minuten ansetzen, um einen für eine neue, moderne Oberfläche zu begeistern, müssen deren Zweifel schon recht groß sein, dass es beim Anwender gut ankommen wird. Normalerweise erwartet man bei sowas doch ein "WOW! - GEIL! - HABEN WILL"
FBauer
Allen Menschen ist das Denken erlaubt - den meisten bleibt es erspart ...
Johannes Anacker
erstellt am: 15. Jan. 2016 10:21    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
... und könnte mir vorstellen, dass da auch ein Aufseufzen durch die Phalanx der vielen Supporter gegangen ist, die in den letzten Wochen und Monaten die Änderung des Userinterfaces als wertvolle Neuerung verteidigt haben und jetzt zumindest eine zukünftige Option anbieten können (   Jo, Heiko, Andi )
Ciao,
Stefan
Hi Stefan!
Natürlich habe ich (und Heiko, Andi und viele andere) letzten Herbst die geänderte Oberfläche vorgestellt, lässt sich ja nicht vermeiden  . War wie immer das erste Thema der Präsentation. Allerdings wurde die neue Farbgebung von mir nur kurz erwähnt, mit Hinweis auf MS Office (wo ja auch alles blasser geworden ist). Danach ging es direkt zu den "breadcrumbs", die ich persönlich sehr gelungen finde. Mein Spruch war dann sinngemäß: "Damit wir uns weniger von den neuen Farben ablenken lassen müssen, gibt es jetzt die breadcrumbs und die "D"-Taste."
Schön ist aber, dass SWX Corp. die Bedenken der Anwender (Kunden, Reseller und sicher auch SWX-Mitarbeiter) erkannt hat. Wenn man bedenkt, wie die Oberfläche noch in beta1 aussah ... ich freue mich auf SP3
ciao
jo
Johannes Anacker
SolidLine AG
Alexx2
design engineer
Sehen Sie sich das Profil von Alexx2 an!   Senden Sie eine Private Message an Alexx2  Schreiben Sie einen Gästebucheintrag für Alexx2
SWX2015X64SP5.0
Win7X64
Xeon
K2000
12g
erstellt am: 15. Jan. 2016 10:53    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
AyAyAyy! Arriba!!!
PKC
Sehen Sie sich das Profil von PKC an!   Senden Sie eine Private Message an PKC  Schreiben Sie einen Gästebucheintrag für PKC
SolidWorks 2015
erstellt am: 17. Jan. 2016 17:56    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Sehr schön, die Farben kommen sogar rechtzeitig zum angedachten Update zurück.
Da sieht man mal was Kundenmeinung alles bewirken kann.
PKC
ublum
SolidWorks2016
AutoCad2016
DDS2016
erstellt am: 24. Mrz. 2016 08:22    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Es ist soweit.
Ab jetzt treiben wir es wieder fast durchgängig bunt
im EV des SP3 sind die Farben drin (Bilder)
Da kann man nur sagen Hut ab und steter Tropfen höhlt den Stein.
Grüße von der Saar
Uwe Blum
www.hydac.com/
[Diese Nachricht wurde von ublum am 24. Mrz. 2016 editiert.]
Johannes Anacker
erstellt am: 24. Mrz. 2016 09:12    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
"klassisch"  --> SOLIDWORKS ist halt ein Klassiker!
Danke für die Info, Uwe!
Ciao
Johannes Anacker
SolidLine AG
ad_man
freiberuflicher Entwicklungsing. (Fahrzeugtechnik, CSWP)
erstellt am: 22. Apr. 2016 16:56    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
jetzt ist die Farbe im Userinterface wieder da, dafür sind die Icons im
Windows-Explorer wieder blau. Die kann man(n)/frau bescheiden auseinanderhalten.
Weiß jemand, wie man wieder die gelb/grünen Symbole zurückbekommt?
PS: Ich setzte Windows 10 ein...
Andreas
ublum
SolidWorks2016
AutoCad2016
DDS2016
erstellt am: 25. Apr. 2016 10:09    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
leider gar nicht...
sehr ärgerlich, abder SWX will so wohl die Anwender davon überzeugen, dass das neue Layout das Bessere ist.
Grüße von der Saar
Uwe Blum
www.hydac.com/
Carsten1210
staatl. geprüfter Holztechniker
Sehen Sie sich das Profil von Carsten1210 an!   Senden Sie eine Private Message an Carsten1210  Schreiben Sie einen Gästebucheintrag für Carsten1210
AutoCAD ACA 2016
Solidworks 2015 Sp3
Enterprise PDM 2015 Sp3
Pascam Woodworks
Windows 7 64Bit
Intel Core i7-4790K
16 GB Arbeitsspeicher
2x Samsung S24C650
Dell M4800
erstellt am: 25. Apr. 2016 10:30    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Hi Andreas,
Laut dem Forum auf Solidworks.com sind die Explorer-Icons hier gespeichert:
SWPart.ico, SWAssem.ico, and SWDrawing.ico are stashed here: C:\Windows\Installer\{768F3B65-1695-47B7-9002-B11400CB111D}
Habe es selber aber noch nicht getestet.
Gruss, Carsten
KMassler
CAD Admin + Mädchen für Alles...
** CSWP 01/2008 **
(noch) HP Z400, 8GB, Quadro FX 2000 :(
SWX2016 SP4;
SAP/PLM;
DriveWorks Pro;
Programmierung: VBA, Relikte mit VB6, aktuell VB.NET 2015
erstellt am: 25. Apr. 2016 11:16    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Das ist wohl Versionsabhängig sein, bei mir sind die hier:
SWX 2013:
C:\Windows\Installer\{B6B5EA7E-B91F-443D-A958-B0062FB53804}
SWX 2016:
(wie bei dir)
Klaus
www.al-ko.com | mein Gästebuch
[Diese Nachricht wurde von KMassler am 25. Apr. 2016 editiert.]
ad_man
erstellt am: 25. Apr. 2016 11:22    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für ublum 10 Unities + Antwort hilfreich
Moin Carsten,
leider hat ein Austausch der Icons, ich hatte noch welche im SWX2015 Verzeichnis
gefunden, nichts gebracht. Ich habe auch den Iconcache mal gelöscht, aber
die Verknüpfung muss irgendwo anders passieren
Andreas
(c)2017 CAD.de
