Moin zusammen,
habe ein kleines Problem mir dem Export von IGES.
Benutze noch die Version 10.50 von ME10 und den dazugehörigen iges2d Konverter.
Der Export funktioniert ohne Fehler, die Probleme tauchen beim Import der Datei auf:
snip___________________________
Global section of IGES file
Product Identification From Sender ..........
File Name ................................... c:\tmp\test.igs
System ID ................................... CoCreate ME10 IGES 2D Translator Release 13.20B (build 342.34)
Preprocessor Version ........................ Release 13.20B (build 342.34)
Number of Bits for Integer Representation ... 32
Single Precision Magnitude .................. 308
Single Precision Significance ............... 15
Double Precision Magnitude .................. 308
Double Precision Significance ............... 15
Product Identification for Receiver .........
Model Space Scale ........................... 1
Unit Flag ................................... 2
Units ....................................... MM
Maximum Number of Line Weight Gradations .... 1
Size of Maximum Line Width in Units ......... 1
Date and Time of File Generation ............ 060224.111233
Minimum User-Intended Resolution ............ 1.22939E-007
Approximate Maximum Coordinate Value ........ 122939
Name of Author ..............................
Organization ................................
IGES Version Number ......................... 9
Drafting Standard Code ...................... 0
Error Report
>>>W Line (DE: 5273 PD: 5698)
Length of line less than minimum resolution
>>>W Line (DE: 5277 PD: 5702)
>>>W Line (DE: 5359 PD: 5795)
>>>W Line (DE: 6435 PD: 7030)
>>>W Line (DE: 6661 PD: 7278)
>>>W Line (DE: 6763 PD: 7403)
>>>W Line (DE: 6785 PD: 7425)
>>>W Line (DE: 6925 PD: 7591)
>>>W Line (DE: 7389 PD: 8103)
>>>W Line (DE: 8303 PD: 9042)
>>>W Line (DE: 8341 PD: 9080)
>>>W Composite Curve (DE: 8571 PD: 9359)
Gap detected between constituent entities
>>>W Composite Curve (DE: 8573 PD: 9360)
Kann da jemand helfen??
