Thema: Automatic by API SaveAs vs. Export (1686 mal gelesen)
Holzknoten Mitglied
Beiträge: 10 Registriert: 09.10.2011 AutoCAD 2013, Top Solid 2013
erstellt am: 23. Feb. 2014 12:43 <-- editieren / zitieren --> Unities abgeben:
Hi TopSolid users and supporter, i want to automaticly export my files in mutiple formats (dwg/dxf/pdf/jpg) For that i use the following code of the API-help-file.
Code: IDocument.Export(Path, InterfaceProvider, Ask)
or Code: IDocument.SaveAs(Name, Ask)
My working steps in VB with SaveAs for a Designfile (.top) and Draftfile (.dft)
Code: ... IDocument.SaveAs("C:\test.dwg", True) IDocument.SaveAs("C:\test.dxf", True) IDocument.SaveAs("C:\test.jpg", True)
My working steps in VB with Export for a Designfile (.top) and Draftfile (.dft)
Code: ... IDocument.Export("C:\test.dwg", "dwg", True) IDocument.Export("C:\test.dxf", "dxf", True) IDocument.Export("C:\test.jpg", "jpg", True)
My working steps in VB with Export for a Draftfile (.dft) only. [color=red]Why not for a Designfile (.top)?[/color]
Code: ... IDocument.Export("C:\test.pdf", "pdf", True)
But what is about the [color=red]Ask[/color] of... IDocument.Export(Path, InterfaceProvider, [color=red]Ask[/color]) The API-help-file says:
Zitat: Ask user for confirmation before saving modified referenced files (optional, default = False).
When i use True or False it doesn't matter. Where can i change the options of dwg?
Zitat: IApplication.SetExportOption(Extension, Name, Value) AutoCAD (dxf, dwg) : format : "dxf", "dwg", "binary dxf". unit : "mm", "cm", "m", "km", "µm", "ft", "in", "mil", "mile", "µin". version : "2.5", "2.6", "9", "10", "11", "12", "13", "14", "2000".
Example i used before Export-function:
Code: App.SetExportOption("dxf", "unit", "mm") App.SetExportOption("dxf", "format", "dwg") App.SetExportOption("dxf", "version", "2000")
The DWG-file is everytime saved in the highest version(2013) Any experience about that? ------------------ mfg Holzknoten [Diese Nachricht wurde von Holzknoten am 23. Feb. 2014 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
| Anzeige.:
