  CATIA V5 Programmierung
  Macro for exporting Tif and for modify text
Autor Thema:  Macro for exporting Tif and for modify text (571 mal gelesen)
lukeumbo
Sehen Sie sich das Profil von lukeumbo an!   Senden Sie eine Private Message an lukeumbo  Schreiben Sie einen Gästebucheintrag für lukeumbo
CATIA V5 R24
erstellt am: 03. Dez. 2018 12:11    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Macro-ToTif.zip
Hi to all,
Often I need to export many CatDrawing to tif.
I want to set a directory for input and one for output. Drawings may contain multiple sheets.
I have 2 scripts (see attachments). Each one do partially what I want to do.
One script can manage multiple sheets but convert only 1 file and it need to be open.
The other script don't need that the Drawings are open but it don't manage multiple sheets and convert only the active sheet.
Is there a way to "merge" these script to do the whole work?
I don't know vba or scripting so I can't understand if it's possible to do.
The second question is about texts.
Our title block is automatically generated by the system when I create a Drawing.
I want to change some text size/Ratio/Spacing with a macro.
I tried this (actually only for text size):
Language="VBSCRIPT"
Sub CATMain()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "Name=Testo.180,all"
Set A3 = selection1
A3.SetFontSize 0,0,2.2
The macro won't work and break on "A3.SetFontSize 0,0,2.2".
I've found "SetFontSize" on a tutorial but I can't understand if is wrong the command or the way I used it.
For Texts Ratio and Spacing is there a command? I can find anything on the net
I'm on Catia R24
p.s.: sorry for my bad english
Thanks
LuKe
bgrittmann
CATIA V5R19
erstellt am: 03. Dez. 2018 13:28    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für lukeumbo 10 Unities + Antwort hilfreich
Hi Luke
Welcome to the forum.
Your code is not working, because you have to apply the method to a text and not to the whole selection:
Code:
Set A3 = selection1.item2(1).value  '1st selected element
Text ration and spacing should work as following (not tested):
Code:
A3.SetParameterOnSubString catCharRatio, 0, 0, 2
A3.SetParameterOnSubString catCharSpacing, 0, 0, 2
Regards,
lukeumbo
CATIA V5 R24
erstellt am: 04. Dez. 2018 16:32    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
It works fine
Many thanks for your support
If you have any advise for my other problem about exporting in tif it will be welcome
LuKe
