Code:
Option Explicit
Public Sub prcTest()
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim partDocument1 As PartDocument
Set partDocument1 = documents1.Item("Kabelkanal.CATPart")
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim TheSpaWorkbench As Workbench
Set TheSpaWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Dim intColumn As Integer
Dim lngRow As Long
Dim vntSortArray As Variant
'die zu sortierenden Spalten
'negative Zahl = Spalte absteigend sortieren
'positive Zahl = Spalte aufsteigend sortieren
vntSortArray = Array(1)
'Selection starten und nach allen Fills suchen------------------------------------------------------------
Dim selection01 As Selection
Set selection01 = CATIA.ActiveDocument.Selection
selection01.Search ".Fill.name=Fill*;all"
Dim E As Long
E = selection01.Count2
ReDim flaecheArray(1 To E, 1 To 2)
'E zur Info und als Max-Wert für die Schleife-------------------------------------------------------------
'flaecheArray befüllen mit Fläche (gerundet) und Namen der einzelnen Flächen -----------------------------
Dim Wert
Dim Referenz
Dim Measurable01
Dim I As Long
For I = E To 1 Step -1
Set Wert = selection01.Item(I).Value
Set Referenz = part1.CreateReferenceFromObject(Wert)
Set Measurable01 = TheSpaWorkbench.GetMeasurable(Referenz)
flaecheArray(I, 1) = Measurable01.Area
flaecheArray(I, 1) = Round(flaecheArray(I, 1), 6) * 1000000
flaecheArray(I, 2) = Wert.Name
Next
part1.Update
'Sortierroutine starten
Call prcSort(vntSortArray, flaecheArray())
'Ausgabe Testarray
Application.ScreenUpdating = False
' Range("A1:A10000").Value = flaecheArray
Application.ScreenUpdating = True
End Sub
Private Sub prcSort(vntSortArray As Variant, flaecheArray() As Variant)
Dim intIndex As Integer
Dim lngIndex1 As Long, lngIndex2 As Long, lngRowsArray() As Long
Dim lngRowsCount As Long, lngRangeCount As Long
Dim vntTemp As Variant
ReDim lngRowsArray(0 To 1, 0 To UBound(flaecheArray) * 2)
'Array für den 1. Sortierlauf
lngRowsArray(0, 0) = LBound(flaecheArray)
lngRowsArray(0, 1) = UBound(flaecheArray)
lngRowsCount = 1
For intIndex = LBound(vntSortArray) To UBound(vntSortArray)
'Wenn eine Spalte angegeben
If vntSortArray(intIndex) <> 0 Then
lngRangeCount = -1
'Schleife zum sortieren der einzelnen Bereiche
For lngIndex1 = 0 To lngRowsCount Step 2
'Sortieren des Bereichs, wenn Zeilenzahl größer 1
If lngRowsArray(0, lngIndex1) <> lngRowsArray(0, lngIndex1 + 1) Then
Call prcQuickSort(CLng(lngRowsArray(0, lngIndex1)), _
CLng(lngRowsArray(0, lngIndex1 + 1)), CInt(Abs(vntSortArray(intIndex))), _
CBool(vntSortArray(intIndex) > 0), flaecheArray())
'sortierten Bereich merken
lngRangeCount = lngRangeCount + 2
lngRowsArray(1, lngRangeCount - 1) = lngRowsArray(0, lngIndex1)
lngRowsArray(1, lngRangeCount) = lngRowsArray(0, lngIndex1 + 1)
End If
Next
lngRowsCount = -1
'Durchsuchen der soeben sortierten Spalte nach Wertewechsel
For lngIndex1 = 0 To lngRangeCount Step 2
'1. Zeile des zu sortierenden Bereichs
vntTemp = flaecheArray(lngRowsArray(1, lngIndex1), Abs(vntSortArray(intIndex)))
lngRowsCount = lngRowsCount + 1
lngRowsArray(0, lngRowsCount) = lngRowsArray(1, lngIndex1)
'Suche nach Wechsel innerhalb des Bereichs
For lngIndex2 = lngRowsArray(1, lngIndex1) To lngRowsArray(1, lngIndex1 + 1)
If vntTemp <> flaecheArray(lngIndex2, Abs(vntSortArray(intIndex))) Then
lngRowsCount = lngRowsCount + 2
lngRowsArray(0, lngRowsCount - 1) = lngIndex2 - 1
lngRowsArray(0, lngRowsCount) = lngIndex2
vntTemp = flaecheArray(lngIndex2, Abs(vntSortArray(intIndex)))
End If
Next
'letzte Zeile des zu sortierenden Bereichs
lngRowsArray(0, lngRowsCount) = lngRowsArray(1, lngIndex1 + 1)
Next
End If
Next
End Sub
Private Sub prcQuickSort(lngLbound As Long, lngUbound As Long, _
intSortColumn As Integer, bntSortKey As Boolean, flaecheArray() As Variant)
Dim vntTemp As Variant, vntBuffer As Variant
lngIndex1 = lngLbound
lngIndex2 = lngUbound
vntBuffer = flaecheArray((lngLbound + lngUbound) \ 2, intSortColumn)
Do
If bntSortKey Then
Do While flaecheArray(lngIndex1, intSortColumn) < vntBuffer
lngIndex1 = lngIndex1 + 1
Loop
Do While vntBuffer < flaecheArray(lngIndex2, intSortColumn)
lngIndex2 = lngIndex2 - 1
Loop
Else
Do While flaecheArray(lngIndex1, intSortColumn) > vntBuffer
Loop
Do While vntBuffer > flaecheArray(lngIndex2, intSortColumn)
Loop
End If
If lngIndex1 < lngIndex2 Then
If flaecheArray(lngIndex1, intSortColumn) <> _
flaecheArray(lngIndex2, intSortColumn) Then
For intIndex = LBound(flaecheArray, 2) To UBound(flaecheArray, 2)
vntTemp = flaecheArray(lngIndex1, intIndex)
flaecheArray(lngIndex1, intIndex) = _
flaecheArray(lngIndex2, intIndex)
flaecheArray(lngIndex2, intIndex) = vntTemp
Next
End If
ElseIf lngIndex1 = lngIndex2 Then
End If
Loop Until lngIndex1 > lngIndex2
If lngLbound < lngIndex2 Then Call prcQuickSort(lngLbound, _
lngIndex2, intSortColumn, bntSortKey, flaecheArray())
If lngIndex1 < lngUbound Then Call prcQuickSort(lngIndex1, _
lngUbound, intSortColumn, bntSortKey, flaecheArray())
End Sub
Sub Excel1()
On Error Resume Next
Dim Excel As Object
Set Excel = GetObject(, "EXCEL.Application")
'Bevor Excel geöffnet wird, muss es geschlossen sein !!! -------------------------------------------------
If Err.Number <> 0 Then
Err.Clear
Set Excel = CreateObject("Excel.Application")
Else
Err.Clear
MsgBox "Please note you have to close Excel", vbCritical
Exit Sub
End If
' Alle Objekte für Excel deklarieren ---------------------------------------------------------------------
Dim workbooks As workbooks
Dim workbook As workbook
Dim Sheets As Object
Dim Sheet As Object
Dim worksheet As Excel.worksheet
Dim myworkbook As Excel.workbook
Dim myworksheet As Excel.worksheet
Set workbooks = Excel.Applcation.workbooks
Set myworkbook = Excel.workbooks.Add
Set myworksheet = Excel.ActiveWorkbook.Add
Dim partDoc As Object
Set partDoc = CATIA.ActiveDocument.Part
Dim docname As String
docname = partDoc.Name
Dim objSPAWkb
Set objSPAWkb = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
Excel.Visible = True
'Formatierung der Ersten Zeilen --------------------------------------------------------------------------
Excel.Range("A:A").ColumnWidth = 15
Excel.Range("B:B").ColumnWidth = 15
Excel.Range("A:B").Font.Name = "Arial"
Excel.Range("A:B").Font.Size = 20
'Formatierung der Ersten Zellen --------------------------------------------------------------------------
Excel.Range("1:1").Font.Bold = True
Excel.Range("1:1").RowHeight = 20
Excel.Range("1:1").Font.Size = 12
'Befüllung Reihe Eins ------------------------------------------------------------------------------------
Excel.Cells(1, 1) = "Name"
Excel.Cells(1, 2) = "Querschnitt"
'Befüllung ab Reihe Zwei ---------------------------------------------------------------------------------
Excel.Range(Cells(2, 1), Cells(E, 2)) = flaecheArray
End Sub
