Code:
Sub CATMain()Wersja.Hide
'_________________________________________
' Separating char
Dim trz As String, crlf As String
trz = ";"
crlf = Chr(10)
'RegEx
Dim reg As String
reg = "([\w]{3}\.[\w]{3}\.[\w]{3})"
Set Document = CATIA.ActiveDocument
Set filesys = CATIA.FileSystem
CATIA.ActiveWindow.ActiveViewer.Reframe
'__________________________________________________________________________
' Filename and path
'on error resume next
Dim Nfile As String
Nfile = Document.name
Dim path As String, Nazwa As String, filename As String
path = Left(Document.FullName, InStrRev(Document.FullName, "\"))
pathdummy = Left(path, Len(path) - 1)
Nazwa = Left(Nfile, InStr(Nfile, ".") - 1)
If Wersja.PT_all = True Then
filename = "D:\" & Nazwa & "_point_exp_all"
ElseIf Wersja.PT_scr = True Then
filename = "D:\" & Nazwa & "_point_exp_visible"
ElseIf Wersja.PT_NoShow = True Then
filename = "D:\" & Nazwa & "_point_exp_not_visible"
End If
Dim selection1 As Selection
Set selection1 = Document.Selection
selection1.Clear
selection1.Search "((((CATStFreeStyleSearch.Point + CATSketchSearch.2DPoint) + CATDrwSearch.2DPoint) + CATPrtSearch.Point) + CATGmoSearch.Point),all"
selection1.Search "((((CATStFreeStyleSearch.Point + CATSketchSearch.2DPoint) + CATDrwSearch.2DPoint) + CATPrtSearch.Point) + CATGmoSearch.Point),scr"
CATIA.ActiveDocument.SeeHiddenElements = True
End If
If Err <> 0 Then
MsgBox ("Didn't find any points!")
End If
Dim coords(2)
Dim Params
Dim name, Cname
Dim Splitnametemp
Dim A As String, B As String, C As String, D As String
Set Params = Document.Part.Parameters
'ograniczenie tylko do SWP
Dim SWP_kol As New VBA.Collection
Dim MAG_kol As New VBA.Collection
Dim MIG_kol As New VBA.Collection
Dim LaserS_kol As New VBA.Collection
Dim Abt_kol As New VBA.Collection
Dim Kleb_kol As New VBA.Collection
Dim CMAG_kol As New VBA.Collection
Dim CMIG_kol As New VBA.Collection
Dim CLaserS_kol As New VBA.Collection
For i = 1 To selection1.Count
Set Element = selection1.Item(i)
Set Point = Element.Value
name = Params.GetNameToUseInRelation(Point)
If InStr(1, name, "\MAG") <> 0 Then
MAG_kol.Add Point
ElseIf InStr(1, name, "\MIG") <> 0 Then
MIG_kol.Add Point
ElseIf InStr(1, name, "\LaserS") <> 0 Then
LaserS_kol.Add Point
ElseIf InStr(1, name, "\Abdichtungen") <> 0 Then
Abt_kol.Add Point
ElseIf InStr(1, name, "\Klebungen") <> 0 Then
Kleb_kol.Add Point
ElseIf InStr(1, name, "\SWP und Naehte") <> 0 Then
SWP_kol.Add Point
End If
Next
'tworzenie EXCELa
Dim Excel As Object
Dim workbooks1 As workbooks
Dim workbook1 As Workbook
Dim sheets As Object
Dim sheet As Object
Dim worksheet As Excel.worksheet
Dim wrkbook As Excel.Workbook
Dim worksh2 As Excel.worksheet
Set Excel = CreateObject("EXCEL.application")
Excel.Visible = True
Set workbooks1 = Excel.workbooks
Set workbook1 = workbooks1.Add
workbook1.SaveAs filename
workbook1.ActiveSheet.name = "OUT_PPS"
Excel.Cells(1, 1) = "Point Name"
Excel.Cells(1, 2) = "X-Coor"
Excel.Cells(1, 3) = "Y-Coor"
Excel.Cells(1, 4) = "Z-Coor"
Excel.Cells(1, 5) = "Technologia"
Excel.Columns(6).NumberFormat = "@"
Excel.Cells(1, 6) = "Joint Group"
'-----------------------------------SWP----------------------------
For s = 1 To SWP_kol.Count
Set Element = SWP_kol.Item(s)
Set Point = Element '.Value
Point.name = "Point." & s
Point.GetCoordinates coords
Splitnametemp = Split(name, "\")
Excel.Cells(s + 1, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + 1, 2) = coords(0)
Excel.Cells(s + 1, 3) = coords(1)
Excel.Cells(s + 1, 4) = coords(2)
Excel.Cells(s + 1, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + 1, 6) = Mid(Splitnametemp(0), 33, 3)
Next
'-----------------------------------MAG----------------------------
For k = 1 To MAG_kol.Count
Set Element = MAG_kol.Item(k)
Point.name = "Point." & s + k - 1
Excel.Cells(s + k, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + k, 2) = coords(0)
Excel.Cells(s + k, 3) = coords(1)
Excel.Cells(s + k, 4) = coords(2)
Excel.Cells(s + k, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 2)
Excel.Cells(s + k, 6) = Mid(Splitnametemp(0), 33, 3)
Next
'-----------------------------------MIG----------------------------
For n = 1 To MIG_kol.Count
Set Element = MIG_kol.Item(n)
Point.name = "Point." & s + k + n - 2
Excel.Cells(s + k + n - 1, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + k + n - 1, 2) = coords(0)
Excel.Cells(s + k + n - 1, 3) = coords(1)
Excel.Cells(s + k + n - 1, 4) = coords(2)
Excel.Cells(s + k + n - 1, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 2)
Excel.Cells(s + k + n - 1, 6) = Mid(Splitnametemp(0), 33, 3)
Next
'-----------------------------------LASER_S----------------------------
For no = 1 To LaserS_kol.Count
Set Element = CLaserS_kol.Item(no)
Point.name = "Point." & s + k + n + no - 3
Excel.Cells(s + k + n + no - 2, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + k + n + no - 2, 2) = coords(0)
Excel.Cells(s + k + n + no - 2, 3) = coords(1)
Excel.Cells(s + k + n + no - 2, 4) = coords(2)
Excel.Cells(s + k + n + no - 2, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 2)
Excel.Cells(s + k + n + no - 2, 6) = Mid(Splitnametemp(0), 33, 3)
Next
'-----------------------------------ABDICHTUNGEN----------------------------
For abd = 1 To Abt_kol.Count
Set Element = Abt_kol.Item(abd)
Point.name = "Point." & s + k + n + no + abd - 4
Excel.Cells(s + k + n + no + abd - 3, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + k + n + no + abd - 3, 2) = coords(0)
Excel.Cells(s + k + n + no + abd - 3, 3) = coords(1)
Excel.Cells(s + k + n + no + abd - 3, 4) = coords(2)
Excel.Cells(s + k + n + no + abd - 3, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 2)
Excel.Cells(s + k + n + no + abd - 3, 6) = Mid(Splitnametemp(0), 33, 3)
Next
'-----------------------------------KLEBUNGEN----------------------------
For kl = 1 To Kleb_kol.Count
Set Element = Kleb_kol.Item(kl)
Point.name = "Point." & s + k + n + no + abd + kl - 5
Excel.Cells(s + k + n + no + abd + kl - 4, 1) = Left(Splitnametemp(3), Len(Splitnametemp(3))) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 1)
Excel.Cells(s + k + n + no + abd + kl - 4, 2) = coords(0)
Excel.Cells(s + k + n + no + abd + kl - 4, 3) = coords(1)
Excel.Cells(s + k + n + no + abd + kl - 4, 4) = coords(2)
Excel.Cells(s + k + n + no + abd + kl - 4, 5) = Splitnametemp(2) 'Left(Splitnametemp(UBound(Splitnametemp)), Len(Splitnametemp(UBound(Splitnametemp))) - 2)
Excel.Cells(s + k + n + no + abd + kl - 4, 6) = Mid(Splitnametemp(0), 33, 3)
Next
CATIA.ActiveDocument.Part.Update
End Sub
