Code:
'Neuen PartNamen abfragen
Set product = oDocument.Product
Set products = product.Products
Set oSel = oDocument.Selection'StartPart in die Struktur laden
Dim arrayOfVariantOfBSTR(0)
arrayOfVariantOfBSTR(0) = "J:\Makros\StartParts\XXX_TEIL-PAD_XXX.CATPart"
products.AddComponentsFromFiles arrayOfVariantOfBSTR, "All"
'Vergabe der neuen PartNumber + InstanceName / Prüfen ob PartNumber bereits vorhanden
isSaved = False
while isSaved = False
myFunc = InputBox ("Bitte vergeben Sie einen neuen Namen.", "PartName", "XXXXXXXX-Y-CC_PLATTE_XX")
If myFunc = "" Then
'PART.Delete
Exit Sub
End If
On Error Resume Next
Set documents = CATIA.Documents
Set partDocument = documents.Item("XXX_TEIL-PAD_XXX.CATPart")
strPath = oDocument.Path
Set oName = products.GetItem("XXX_TEIL-PAD_XXX.1")
oName.Name = myFunc & ".1"
Set oNumber = partDocument.GetItem("XXX_TEIL-PAD_XXX")
oNumber.PartNumber = myFunc
If Err.Number <> 0 Then
RetCode = MsgBox("Diese PartNumber existiert bereits in der Struktur." & vbLF & _
"----------------------------------------------------" & vbLF & _
"Sie müssen eine neue PartNumber vergeben!", 48 + vbYesNo, "Warnung!!!")
Select Case RetCode
Case vbNo
'PART.Delete
Exit Sub
End Select
'Part abspeichern
Else
SavePart strPath, myFunc, partDocument
isSaved = True
End If
Wend
On Error GoTo 0
End Sub
Sub SavePart(ByVal strPath As String, ByVal myFunc As String, ByVal partDocument As Document)
'Geladenes StartPart im Projektordner speichern
strFileName = strPath & "\" & myFunc
partDocument.SaveAs strFileName
On Error GoTo 0
End Sub
