Code:
Option Explicit
' COPYRIGHT DASSAULT SYSTEMES 2002' ***********************************************************************
' Purpose: This macro allows you to create a title block
' from Drawing Table
' Author:
' Languages: VBScript
' Locales: English
' CATIA Level: V5R10
Sub CATMain()
' Set the CATIA popup file alerts to False
' It prevents to stop the macro at each alert during its execution
CATIA.DisplayFileAlerts = False
' Optional: allows to find the sample wherever it's installed
dim sDocPath As String
sDocPath=CATIA.SystemService.Environ("CATDocView")
If (Not CATIA.FileSystem.FolderExists(sDocPath)) Then
Err.Raise 9999,,"No Doc Path Defined"
End If
' Variables declaration
Dim oDrwDocument As DrawingDocument
Dim oDrwSheets As DrawingSheets
Dim oDrwSheet As DrawingSheet
Dim oDrwView As DrawingView
Dim oDrwTables As DrawingTables
Dim oDrwTable As DrawingTable
' Create a new drawing document
Set oDrwDocument = CATIA.Documents.Add("Drawing")
' Set the drawing document standard
oDrwDocument.Standard = catISO
' Retrieve the drawing document's sheets collection
Set oDrwSheets = oDrwDocument.Sheets
' Retrieve the active sheet
Set oDrwSheet = oDrwSheets.ActiveSheet
' Set the sheet properties
oDrwSheet.PaperSize = catPaperA4
oDrwSheet.Orientation = catPaperLandscape
oDrwSheet.Scale2 = 1
' Retrieve the active view of the sheet
Set oDrwView = oDrwSheet.Views.ActiveView
' Retrieve the view's tables collection
Set oDrwTables = oDrwView.Tables
' Create a new drawing table
Set oDrwTable = oDrwTables.Add(107, 70, 9, 9, 5, 20)
' Set the drawing table's name
oDrwTable.Name = "Title Block"
' Do not update drawing table modifications
oDrwTable.ComputeMode = CatTableComputeOFF
' Merge drawing table's cells
oDrwTable.MergeCells 1, 1, 2, 2
oDrwTable.MergeCells 1, 3, 1, 7
oDrwTable.MergeCells 2, 3, 2, 7
oDrwTable.MergeCells 4, 3, 1, 7
oDrwTable.MergeCells 5, 4, 1, 5
oDrwTable.MergeCells 6, 3, 2, 1
oDrwTable.MergeCells 6, 4, 2, 5
oDrwTable.MergeCells 6, 9, 2, 1
oDrwTable.MergeCells 7, 1, 2, 1
oDrwTable.MergeCells 7, 2, 2, 1
oDrwTable.MergeCells 8, 3, 2, 1
oDrwTable.MergeCells 8, 4, 2, 1
oDrwTable.MergeCells 8, 5, 2, 1
oDrwTable.MergeCells 8, 6, 2, 1
oDrwTable.MergeCells 8, 7, 2, 1
oDrwTable.MergeCells 8, 8, 2, 1
oDrwTable.MergeCells 8, 9, 2, 1
' Set the drawing table's row sizes
oDrwTable.SetRowSize 1, 20
oDrwTable.SetRowSize 2, 4
oDrwTable.SetRowSize 3, 5
oDrwTable.SetRowSize 4, 7
oDrwTable.SetRowSize 5, 5
oDrwTable.SetRowSize 6, 7
oDrwTable.SetRowSize 7, 2
oDrwTable.SetRowSize 8, 3
oDrwTable.SetRowSize 9, 7
' Set the drawing table's column sizes
oDrwTable.SetColumnSize 1, 45
oDrwTable.SetColumnSize 2, 20
oDrwTable.SetColumnSize 3, 15
oDrwTable.SetColumnSize 4, 15
oDrwTable.SetColumnSize 5, 27
oDrwTable.SetColumnSize 6, 18
oDrwTable.SetColumnSize 7, 20
oDrwTable.SetColumnSize 8, 15
oDrwTable.SetColumnSize 9, 15
' Update drawing table modifications
oDrwTable.ComputeMode = CatTableComputeON
CATIA.ActiveWindow.ActiveViewer.Reframe
End Sub
