Code:
Sub CATMain()Dim partDocument1 As PartDocument
Dim selection1 As Object
Dim part1 As Part
Dim relations1 As Relations
Dim parameters1 As Parameters
Dim length1 As Length
Dim formula1 As Formula
Dim quellparameter As Parameter
Dim parameterliste() As Variant
Set partDocument1 = CATIA.ActiveDocument
Set selection1 = CATIA.ActiveDocument.Selection
Set part1 = partDocument1.Part
Set relations1 = part1.Relations
Set parameters1 = part1.Parameters
If selection1.Count = 0 Then Exit Sub
ReDim parameterliste(0)
For i = 1 To selection1.Count
ReDim Preserve parameterliste(i)
Set parameterliste(i) = selection1.Item(i).Value
Next
Dim Was(0)
Was(0) = "Parameter"
selection1.Clear
Ergebnis = selection1.SelectElement2(Was, "Bitte den Quellparameter wählen!", False)
If Not Ergebnis = "Normal" Then Exit Sub
Set quellparameter = parameters1.Item(selection1.Item(1).Value.Name)
For i = 1 To UBound(parameterliste)
Set length1 = parameters1.Item(parameterliste(i).Name)
selection1.Clear
selection1.Add length1
CATIA.StartCommand ("löschen")
Set formula1 = relations1.CreateFormula("", "", length1, parameters1.GetNameToUseInRelation(quellparameter))
Next
End Sub
