Super Tipp
wieso bin ich nicht früher darauf gekommen
Ich arbeite mit V5R19
ich hab versucht diesen Code anzupassen, was mir nicht gelungen ist
Code:
Sub CATMain()
'by DANIEL FRAUENRATH
'Version: 1.1
'***DEKLARATION
Dim objPartDoc As PartDocument
Dim objPart As Part
Dim objSPAWB As Workbench
Dim objSel As Selection
Dim strSelString As String
Dim objPointColl() As Object
Dim i As Long
Dim objPoint As Variant
Dim dblYValue As Double
Dim arrPointCoord(2)
Dim booMinusCheck As Boolean
Dim objPointRef As Reference
Dim objMeasurable As Object
Dim objMsgBoxRes As VbMsgBoxResult
Dim objPointFailColl()
Dim objPointPassColl() As Object
'***PART DOKUMENT HOLEN (TYP ABRFRAGE)
On Error Resume Next
Set objPartDoc = CATIA.ActiveDocument
Set objPart = objPartDoc.Part
Set objSPAWB = objPartDoc.GetWorkbench("SPAWorkbench")
If Err.Number <> 0 Then
MsgBox "Das aktive Dokument ist kein CATPart!", vbExclamation, "ABBRUCH"
Exit Sub
Else
On Error GoTo 0
End If
'***PUNKTE SELEKTIEREN
Set objSel = objPartDoc.Selection
objSel.Clear
strSelString = "(((((CATStFreeStyleSearch.Point + CATSketchSearch.2DPoint) + CATDrwSearch.2DPoint) + CATPrtSearch.Point) + CATGmoSearch.Point) + CATSpdSearch.Point),all"
CATIA.HSOSynchronized = False
objSel.Search CStr(strSelString)
CATIA.HSOSynchronized = True
If objSel.Count = 0 Then
MsgBox "Es wurden keine Punkt-Features im Dokument gefunden!", vbExclamation, "KEINE PUNKTE"
objSel.Clear
Exit Sub
Else
ReDim objPointColl(objSel.Count - 1)
ReDim objPointPassColl(objSel.Count - 1)
For i = 0 To objSel.Count - 1
Set objPointColl(i) = objSel.Item(i + 1).Value
Next
objSel.Clear
End If
'***Y-KOORDINATEN ABFRAGEN
ReDim Preserve objPointFailColl(0)
For Each objPoint In objPointColl
If TypeName(objPoint) = "HybridShapePointCoord" Then
lngYValue = objPoint.Y.Value
ElseIf TypeName(objPoint) = "Point2D" Then
Set objPointRef = objPart.CreateReferenceFromObject(objPoint)
Set objMeasurable = objSPAWB.GetMeasurable(objPointRef)
objMeasurable.GetPoint arrPointCoord
lngYValue = arrPointCoord(1)
Else
objPoint.GetCoordinates arrPointCoord
End If
If CheckValue(lngYValue) = True Then
If UBound(objPointFailColl) = 0 Then
ReDim Preserve objPointFailColl(UBound(objPointFailColl) + 2)
Else
ReDim Preserve objPointFailColl(UBound(objPointFailColl) + 3)
End If
Set objPointFailColl(UBound(objPointFailColl) - 2) = objPoint
objPointFailColl(UBound(objPointFailColl) - 1) = objPoint.Name
objPointFailColl(UBound(objPointFailColl)) = lngYValue
End If
Next
'***ERGEBNISSAUSGABE
Dim strMsgTitle As String
Dim objMsgSkin As VbMsgBoxStyle
Dim M1, M2, strMsgBody As String
If UBound(objPointFailColl) <= 1 Then
MsgBox "Es wurden keine Punkte mit negativen Y-Wert gefunden!", vbInformation, "KEINE NEGATIVEN PUNKTE GEFUNDEN"
Else
'***GRUNDEINSTELLUNG MSGBOX
strMsgTitle = "NEGATIVE Y-WERTE GEFUNDEN"
objMsgSkin = vbExclamation + vbYesNo + vbDefaultButton2
M1 = "Folgende Punkte wurden mit negativen Y-Werten indentifiziert!"
M2 = "Wollen Sie den/die Punkte(e) selektieren?"
For i = 0 To UBound(objPointFailColl) Step 3
strMsgBody = strMsgBody + vbNewLine + _
"Punktname:" + vbTab + objPointFailColl(i + 1) + vbNewLine + _
"Y-Koordinate:" + vbTab + CStr(objPointFailColl(i + 2)) + vbNewLine
Next
objMsgBoxRes = MsgBox(M1 + vbNewLine + vbNewLine + strMsgBody + vbNewLine + vbNewLine + M2, objMsgSkin, strMsgTitle)
If objMsgBoxRes = vbYes Then
objSel.Add objPointFailColl(i)
Next
End If
End If
End Sub
Private Function CheckValue(ByVal lngYValue As Double) As Boolean
'***VERGLEICH MIT NULL
If lngYValue < 0 Then
CheckValue = True
Else
CheckValue = False
End If
End Function
