Code:
'bound, hbWork, hbResult, parInfo
'.Run(`Geometrical Set.2\Fuellfl\Input\Boundary.2` ,`Geometrical Set.2\Fuellfl\Work`, `Geometrical Set.2\Fuellfl\Ergebnis` ,`Geometrical Set.2\Fuellfl\Parameters.2\Info` )
'Set mPart = GetPart(hbWork) 'Ausführen außerhalb UDF
set mPart = parInfo.parent.parent 'Ausführung in UDF
call clear(hbWork.HybridBodies.Item(1),mPart)
call clear(hbWork.HybridBodies.Item(2),mPart)
call DisAss(bound,hbWork.HybridBodies.Item(1),mPart)
call CheckCurves(hbWork,bound,mPart)
call CreateFills(hbWork,bound.parent.item(6),mPart)
call JoinAll(hbResult.hybridshapes.item(1),hbWork.HybridBodies.Item(2),mPart)
call clear(hbResult.HybridBodies.Item(1),mPart)
call DisAss(hbResult.hybridshapes.item(1),hbResult.HybridBodies.Item(1),mPart)
call JoinAll(hbResult.hybridshapes.item(1),hbResult.HybridBodies.Item(1),mPart)
End Sub
Sub JoinAll(hsJoin,hbFills,mPart)
Set mHybridShapeFactory = mPart.HybridShapeFactory
for i = hsJoin.GetElementsSize to 1 Step -1
hsJoin.RemoveElement i
next
for i = 1 to hbFills.hybridshapes.count
Set ref_Fill = mPart.CreateReferenceFromObject(hbFills.hybridshapes.item(i))
hsjoin.AddElement ref_Fill
next
mPart.UpdateObject hsjoin
End Sub
Sub CheckCurves(hbWork,bound,mPart)
'''Referenz-Richtungen für Extremum-Erstellung
Set hsDirX = bound.parent.item(3).Dir
Set hsDirY = bound.parent.item(4).Dir
Set hsDirZ = bound.parent.item(5).Dir
'''Referenz-Punkt erstellen - wird später weiter genutzt
Set ref_mCrv = mPart.CreateReferenceFromObject(bound)
Set hybridShapeExtremum1 = mHybridShapeFactory.AddNewExtremum(ref_mCrv, hsDirX, 1)
hybridShapeExtremum1.Direction2 = hsDirY
hybridShapeExtremum1.ExtremumType2 = 1
hybridShapeExtremum1.Direction3 = hsDirZ
hybridShapeExtremum1.ExtremumType3 = 1
mPart.UpdateObject hybridShapeExtremum1
refCoord = GetCoord(hybridShapeExtremum1,mPart)
'msgbox cstr(refCoord(0)) & ":" & cstr(refCoord(1)) & ":" & cstr(refCoord(2))
set hbCurves = hbWork.HybridBodies.Item(1)
for i = hbCurves.HybridShapes.count to 1 Step -1
Set ref_mCrv = mPart.CreateReferenceFromObject(hbCurves.hybridshapes.item(i))
'Extremum zum Vergleich erstellen
hybridShapeExtremum1.ReferenceElement = ref_mCrv
'Werte ermitteln und vergleichen
tarCoord = GetCoord(hybridShapeExtremum1,mPart)
if (tarcoord(0)=refCoord(0)) and (tarcoord(1)=refCoord(1)) and (tarcoord(2)=refCoord(2)) then
mHybridShapeFactory.DeleteObjectForDatum(ref_mCrv)
end if
next
end Sub
Function GetCoord(oP,mPart)
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench ( "SPAWorkbench" )
Set ref_oP = mPart.CreateReferenceFromObject(oP)
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(ref_oP)
Dim Coordinates(2)
TheMeasurable.GetPoint Coordinates
GetCoord = Coordinates
end function
Sub DisAss(bound, hbWork,mPart)
''' MUSS, DA BEI DIREKTER VERWENDUNG DER BOUND ALS UDF "ADDNEWDATUMS" AUF FEHLER LÄUFT!
Set assemble1 = mHybridShapeFactory.AddNewJoin(ref_mCrv, Nothing)
assemble1.SetConnex 0
mPart.UpdateObject assemble1
Set ref_mCrv = mPart.CreateReferenceFromObject(assemble1)
hShapes = mHybridShapeFactory.AddNewDatums(ref_mCrv)
For i4 = 0 To UBound(hShapes)
hbWork.AppendHybridShape hShapes(i4)
Next
End Sub
Sub clear(hb_work,mPart)
for i = hb_work.hybridshapes.count to 1 Step -1
Set ref_mCrv = mPart.CreateReferenceFromObject(hb_work.hybridshapes.item(i))
next
End Sub
Function GetPart(hb)
set obj = hb
set GetPart = nothing
Do
Set obj = obj.parent
If TypeName(obj) = "Part" Then Set GetPart = obj
Loop While GetPart Is Nothing
End Function
Sub CreateFills(hbWork,SurF,mPart)
set hbFills = hbWork.HybridBodies.Item(2)
Set ref_RefSurF = mPart.CreateReferenceFromObject(SurF)
Set hybridShapeFill1 = mHybridShapeFactory.AddNewFill()
hybridShapeFill1.AddBound ref_mCrv
hybridShapeFill1.AddSupportAtBound ref_mCrv, ref_RefSurF
hybridShapeFill1.Continuity = 1
hbFills.AppendHybridShape hybridShapeFill1
mPart.UpdateObject hybridShapeFill1
next
End Sub
