Code:
Language="VBSCRIPT"Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim parameters1 As Parameters
Set parameters1 = part1.Parameters
Dim name As CATBaseDispatch
Set name = partDocument1.GetItem(partNumber)
Dim teilenummer As String
teilenummer = name.partNumber
Dim length1 As Parameter
Set length1 = parameters1.Item(teilenummer + "\Offset_Bbox_Max_X.6")
length1.Value = 1.000000
part1.Update
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim nummer as Integer
nummer = InputBox("Rohrteilnummer eingeben.", "Rohrteilnummer", nummer)
Dim body1 As Body
Set body1 = bodies1.Item("Rohteil." & nummer)
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = body1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("definition_points")
Dim sketches1 As Sketches
Set sketches1 = hybridBody1.HybridSketches
Dim sketch1 As Sketch
Set sketch1 = sketches1.Item("Skizze.3")
Dim constraints1 As Constraints
Set constraints1 = sketch1.Constraints
Dim constraint1 As Constraint
Set constraint1 = constraints1.Item("Länge.1")
Dim length2 As Dimension
Set length2 = constraint1.Dimension
length2.Value = 69.000000
Dim constraint2 As Constraint
Set constraint2 = constraints1.Item("Länge.2")
Dim length3 As Dimension
Set length3 = constraint2.Dimension
length3.Value = 96.000000
Dim parameters2 As Parameters
Set parameters2 = part1.Parameters
Dim length4 As Parameter
Set length4 = parameters2.Item(teilenummer + "\Offset_Bbox_Min_X.2")
length4.Value = 1.000000
part1.Update
Dim parameters3 As Parameters
Set parameters3 = part1.Parameters
Dim length5 As Parameter
Set length5 = parameters3.Item(teilenummer + "\Offset_Bbox_Max_Y.2")
length5.Value = 1.000000
part1.Update
Dim parameters4 As Parameters
Set parameters4 = part1.Parameters
Dim length6 As Parameter
Set length6 = parameters4.Item(teilenummer + "\Offset_Bbox_Min_Y.2")
length6.Value = 1.000000
part1.Update
Dim parameters5 As Parameters
Set parameters5 = part1.Parameters
Dim length7 As Parameter
Set length7 = parameters5.Item(teilenummer + "\Offset_Bbox_Max_Z.2")
length7.Value = 1.000000
part1.Update
Dim parameters6 As Parameters
Set parameters6 = part1.Parameters
Dim length8 As Parameter
Set length8 = parameters6.Item(teilenummer + "\Offset_Bbox_Min_Z.2")
length8.Value = 1.000000
part1.Update
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
Dim visPropertySet1 As VisPropertySet
Set visPropertySet1 = selection1.VisProperties
Set hybridBodies1 = hybridBody1.Parent
Dim bSTR1 As String
bSTR1 = hybridBody1.Name
selection1.Add hybridBody1
Set visPropertySet1 = visPropertySet1.Parent
Dim bSTR2 As String
bSTR2 = visPropertySet1.Name
Dim bSTR3 As String
bSTR3 = visPropertySet1.Name
visPropertySet1.SetShow 0
selection1.Clear
Dim sketch2 As Sketch
Set sketch2 = sketches1.Item("Skizze.2")
part1.InWorkObject = sketch2
Dim factory2D1 As Factory2D
Set factory2D1 = sketch2.OpenEdition()
Dim geometricElements1 As GeometricElements
Set geometricElements1 = sketch2.GeometricElements
Dim point2D1 As GeometricElement
Set point2D1 = geometricElements1.Item("Punkt.1")
point2D1.SetData -68.000000, -95.000000
Dim point2D2 As GeometricElement
Set point2D2 = geometricElements1.Item("Punkt.2")
point2D2.SetData 1.000000, -95.000000
Dim line2D1 As GeometricElement
Set line2D1 = geometricElements1.Item("Linie.1")
line2D1.SetData 0.000000, -95.000000, 1.000000, 0.000000
Dim line2D2 As GeometricElement
Set line2D2 = geometricElements1.Item("Linie.2")
line2D2.SetData 1.000000, 0.000000, 0.000000, 1.000000
Dim line2D3 As GeometricElement
Set line2D3 = geometricElements1.Item("Linie.4")
line2D3.SetData -68.000000, 0.000000, 0.000000, 1.000000
sketch2.CloseEdition
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim closeSurface1 As Shape
Set closeSurface1 = shapes1.Item("Rohteil")
part1.InWorkObject = closeSurface1
part1.Update
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
Dim visPropertySet2 As VisPropertySet
Set visPropertySet2 = selection2.VisProperties
Dim bSTR4 As String
bSTR4 = hybridBody1.Name
selection2.Add hybridBody1
Set visPropertySet2 = visPropertySet2.Parent
Dim bSTR5 As String
bSTR5 = visPropertySet2.Name
Dim bSTR6 As String
bSTR6 = visPropertySet2.Name
visPropertySet2.SetShow 1
selection2.Clear
End Sub
