Klappt nicht.
Mitlerweile kann ich mit CreateOptimization die Optimierung erstellen, aber nicht starten.
In V5Automation.chm steht:
Method Index
Run
Runs the optimization as it is defined.
Properties
o Property AlgorithmType( ) As CatAlgorithmType
Returns or sets the algorithm type. Currently available algorithms are gradient and simulatedAnnealing
See also:
CatAlgorithmType
o Property Constraints( ) As CATIAOptimizationConstraints (Read Only)
Returns the collection of optimization constraints.
o Property FreeParameters( ) As CATIAFreeParameters (Read Only)
Returns the collection of the free parameters.
o Property MaxEvalsNb( ) As long
Returns or sets the maximum number of model updates allowed during one run of the optimization.
o Property MaxEvalsWoImprovement( ) As long
Returns or sets the maximum number of model updates without improvement of the problem solution during one run of the optimization.
o Property MaxTime( ) As long
Returns or sets the maximum time allowed for one run of the optimization (in minutes).
o Property ObjectiveParameter( ) As CATIARealParam
Returns or sets the objective parameter of the optimization. This parameter can not exist (in this case the get_ method returns E_FAIL) when the optimization contains only constraints and uses Simulated Annealing, or if the optimization feature doesn't contain all information necessary to be run.
o Property OptimizationType( ) As CatOptimizationType
Returns or sets the type of the optimization: minimum, maximum or target value searched on the objective parameter.
See also:
CatOptimizationType
o Property TargetValue( ) As CATIARealParam (Read Only)
Returns the objective parameter target value. (used only if the optimization type is a target value search)
o Property UseMaxEvalsWoImprovement( ) As boolean
Returns or sets if the number of updates without improvement of the solution has to be used as a termination criterion.
o Property UseMaxTime( ) As boolean
Returns or sets if max time has to be used as a termination criterion.
Methods
o Sub Run( boolean iWithStopDialog)
Runs the optimization as it is defined. The stop dialog appears if argument is TRUE
Before running, a check is made to ensure that the optimization feature contains enough information to run the optimization. In the case where some information is missing, this method returns E_FAIL
WARNING : if argument is TRUE, the optimization is launched asynchronously, and you can not run several optimizations in this mode.
Kann es aber irgendwie nicht anwenden. Bitte um Hilfe.
