das hab ich auf die schnelle in der Doku gefunden vielleicht hilfts was
o Func GetExternalReferencesAsVisibleInfo( CATBSTR ioAdminLevel,
CATBSTR ioLocked) As boolean
Retrieves environment informations for the "ExternalReferencesAsVisible" parameter.
Role:Retrieves the state of the "ExternalReferencesAsVisible" parameter in the current environment.
Parameters:
ioAdminLevel
If the parameter is locked, AdminLevel gives the administration level that imposes the value of the parameter.
If the parameter is not locked, AdminLevel gives the administration level that will give the value of the parameter after a reset.
ioLocked
Indicates if the parameter has been locked.
Returns:
Indicates if the parameter has been explicitly modified or remain to the administrated value.
o Func GetExternalReferencesAssemblyRootContextInfo( CATBSTR ioAdminLevel,
Retrieves environment informations for the "ExternalReferencesAssemblyRootContext" parameter.
Role:Retrieves the state of the "ExternalReferencesAssemblyRootContext" parameter in the current environment.
Parameters:
ioAdminLevel
ioLocked
Returns:
o Func GetExternalReferencesNodeInTreeInfo( CATBSTR ioAdminLevel,
Retrieves environment informations for the "ExternalReferencesNodeInTree" parameter.
Role:Retrieves the state of the "ExternalReferencesNodeInTree" parameter in the current environment.
Parameters:
ioAdminLevel
ioLocked
Returns:
