Hallo Tüftler,
ich habe folgenden Skript in der Online Doku gefunden und hätte gern ein paar Veränderungen vorgenommen.
Wie und wo pack ich die da rein..?
'// COPYRIGHT DASSAULT SYSTEMES 1999
'// Language="VBSCRIPT"
'// Sample of macro to extract the Bill Of Material
'// This CATScript assumes that the user has selected Structural objects
'// from the Specification Viewer or the 3D Window.
'// It is advised that the user understand the VBScript and VBA concepts before
'// attempting to modify the code to suit their needs. Microsoft Excel 97
'// provides excellent documentation on the use of VBScript and VBA.
dim excel as AnyObject
dim workbooks as AnyObject
dim workbook as AnyObject
dim sheets as AnyObject
dim sheet as AnyObject
dim excelTemplate as String
dim excelTemplatePath as String
dim strWB as Workbench
dim strServ as AnyObject
dim currentRow as integer
'// Default path of the excel file template
strCATCommandPath = CATIA.SystemService.Environ("CATCommandPath")
excelTemplate = "SectionQuantityListTemplate.xls"
excelTemplatePath = strCATCommandPath + "\" + excelTemplate
'// User customization of the attributes which will be extracted
dim nbColumns as integer
nbColumns = 12
dim column(12)
column(1) = "MemberType"
column(2) = "SectionName"
column(3) = "FamilyName"
column(4) = "CatalogName"
column(5) = "Length"
column(6) = "PlateType"
column(7) = "Thickness"
column(8) = "Surface"
column(9) = "Wet area"
column(10) = "Volume"
column(11) = "Material"
column(12) = "Mass"
dim posPartNumber as integer
posPartNumber = 1
dim posName as integer
posName = 2
'// Start Excel
Sub StartEXCEL()
Err.Clear
On Error Resume Next
Set excel = GetObject (,"EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set excel = CreateObject ("EXCEL.Application")
End If
excel.Application.Visible = TRUE
set workbooks = excel.Application.WorkBooks
set workbook = workbooks.Add(excelTemplatePath)
Dim strMessage
strMessage = "Error Loading Template File:" + excelTemplatePath + Chr(13)
strMessage = strMessage + Chr(13) + "Check the following...." + Chr(13)
strMessage = strMessage + "(1)Template File has read-write capability" + Chr(13)
strMessage = strMessage + "(2)Template File path is valid"
msgbox (strMessage)
End If
set sheets = workbook.Worksheets
set sheet = sheets("Parameters list")
End Sub
'// Exit Excel
Sub EndEXCEL()
workbook.Close
excel.Quit
End Sub
'// Write in Excel
Sub WriteInExcel(iRow, iColumn, iString)
if (Len(iString) > 0) then
dim whichColumn as integer
whichColumn = 0
Select Case iColumn
Case "PartNumber"
whichColumn = 1
Case "Name"
whichColumn = 2
End Select
if (whichColumn = 0) then
dim NotTheSame as Integer
dim i as Integer
NotTheSame = 0
for i = 1 to nbColumns
NotTheSame = StrComp(column(i), iColumn, 0)
if (NotTheSame = 0) then
whichColumn = 2 + i
Exit for
end if
Next
end if
sheet.Cells(iRow, whichColumn) = iString
sheet.Cells(iRow, whichColumn).Select
end if
End Sub
Sub PrintParameters(iProduct)
dim parameters as Parameters
dim param as Parameter
dim nbParam as integer
WriteInExcel currentRow, "PartNumber", iProduct.PartNumber
WriteInExcel currentRow, "Name", iProduct.Name
dim RefProduct as Product
set RefProduct = iProduct.ReferenceProduct
set parameters = iProduct.ReferenceProduct.Parameters
nbParameters = parameters.Count
dim i as Integer
dim parm as Parameter
if (nbParameters > 0) then
if (column(i) = "Length") then
dim length as double
length = strWB.StrComputeServices.GetLength(iProduct)
if (length > 0) then
WriteInExcel currentRow, column(i), length
end if
Elseif (column(i) = "Thickness") then
dim thickness as double
thickness = strWB.StrComputeServices.GetThickness(iProduct)
if (thickness > 0) then
WriteInExcel currentRow, column(i), thickness
end if
Elseif (column(i) = "Surface") then
dim surface as double
surface = strWB.StrComputeServices.GetSurface(iProduct)
if (surface > 0) then
WriteInExcel currentRow, column(i), surface
end if
Elseif (column(i) = "Wet area") then
dim wetarea as double
wetarea = strWB.StrComputeServices.GetWetArea(iProduct)
WriteInExcel currentRow, column(i), wetarea
Elseif (column(i) = "Volume") then
dim volume as double
volume = strWB.StrComputeServices.GetVolume(iProduct)
WriteInExcel currentRow, column(i), volume
Elseif (column(i) = "Mass") then
dim mass as double
mass = strWB.StrComputeServices.GetMass(iProduct)
WriteInExcel currentRow, column(i), mass
Elseif ( column(i) = "Material") then
set param = parameters.GetItem(RefProduct.Name & "\" & column(i))
if (Err.Number <> 0) then set param = Nothing
if (Not(param Is Nothing)) then
WriteInExcel currentRow, column(i), param.ValueasString
end if
Else
set param = parameters.GetItem(column(i))
end if
end if
Next
end if
End Sub
Sub CATMain()
StartExcel
dim product as Product
dim nbProduct as integer
nbProduct = 0
currentRow = 2
dim doc as Document
dim sel as Selection
set doc = CATIA.ActiveDocument
set strWB = doc.GetWorkbench("StrWorkbench")
set strServ = strWB.StrComputeServices
set sel = doc.Selection
set product = sel.FindObject("CATIAProduct")
Do Until(product Is Nothing)
nbProduct = nbProduct + 1
PrintParameters(product)
if (Err.Number <> 0) then set product = Nothing
currentRow = currentRow + 1
Loop
' EndExcel
End Sub
