In this days I am working on the installation of SmartTeam V5-6R2103 on Windows server 2012.
Computer_name: test
I defined an addition widows user called stadmin havind password xxx
- Oracle 11g DB: imprt ald databases using exp/imp utility: It works fine.
- SQL SERVER 2012: as well this one.
- SmarTeam Software: installed under C:\smarteam folder
- Foundation:
user: test\stadmin
pwd: xxx
license: remote server
- WEb Services: I installed all the roles
user: test\stadmin
pwd: xxx
- Demo: Installation ok. I can see the tables on sql server as well the Smarteam user (I used the sql manager tool)
user: sa
pwd:xxx
- Administration manger: Installation ok. I can see the table on sql server
user: test\stadmin
pwd: xxx
- New Vault Server: works fine.
- Smarteam EDITOR: OK
- CATIA on WIN7 and WIN10: check in check out ok.
Some notes about test:
1. On Client side: check C:\SmarTeam\Bin\SmarTeam.Std.LocalConfiguration.dll. and in tnsnames.ora files (mapping db instance and server machine) if you are using oracle db.
2. On Server side:
- install some network monitoring tool like Microsoft Network Monitor 3.4
- Check the files under Domain Folder
- Remember to restart Vault Services when you do some updateds ().
Cheers,
Mat
[Diese Nachricht wurde von makogo1982 am 15. Mai. 2020 editiert.]
