ich versuche gerade eine bewegte Laserquelle ("moving heatsource") in Ansys WB (transient thermisch oder mit Fluent) zu simulieren.
ich habe ein Youtube video dazu gefunden:
https://www.youtube.com/watch?v=DkAsSXdXG7I
Mit folgenden APDL Code:
! Commands inserted into this file will be executed just prior to the ANSYS SOLVE command.
! These commands may supersede command settings set by Workbench.
! Active UNIT system in Workbench when this object was created: Metric (m, kg, N, s, V, A)
! NOTE: Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
! See Solving Units in the help system for more information.
! /INPUT,HFLUX_func,,,1
*DIM,HEAT_FLX1,TABLE,6,22,1,,,,0 ! The last number corresponds to the ID number for the coordinate system
! Begin of equation: Q(x,y,t)=A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2)
*SET,HEAT_FLX1(0,0,1), 0.0, -999
*SET,HEAT_FLX1(2,0,1), 0.0
*SET,HEAT_FLX1(3,0,1), 0.0
*SET,HEAT_FLX1(4,0,1), 0.0
*SET,HEAT_FLX1(5,0,1), 0.0
*SET,HEAT_FLX1(6,0,1), 0.0
*SET,HEAT_FLX1(0,1,1), 1.0, -1, 0, 0.05, 0, 0, 2 ! "C" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,2,1), 0.0, -2, 0, 1, 2, 2, -1
*SET,HEAT_FLX1(0,3,1), 0, -1, 0, 2, 0, 0, -2
*SET,HEAT_FLX1(0,4,1), 0.0, -3, 0, 1, -2, 17, -1
*SET,HEAT_FLX1(0,5,1), 0.0, -1, 0, 0.01, 0, 0, 1 ! "D" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,6,1), 0.0, -2, 0, 1, -1, 3, 1
*SET,HEAT_FLX1(0,7,1), 0.0, -1, 0, 1, 3, 2, -2
*SET,HEAT_FLX1(0,8,1), 0.0, -2, 0, 0, 0, 0, -1 ! "E" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,9,1), 0.0, -4, 0, 1, -1, 2, -2
*SET,HEAT_FLX1(0,10,1), 0.0, -1, 0, 2, 0, 0, -4
*SET,HEAT_FLX1(0,11,1), 0.0, -2, 0, 1, -4, 17, -1
*SET,HEAT_FLX1(0,12,1), 0.0, -1, 0, 1, -3, 1, -2
*SET,HEAT_FLX1(0,13,1), 0.0, -2, 0, -3, 0, 0, -1 ! "B" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,14,1), 0.0, -3, 0, 1, -2, 3, -1
*SET,HEAT_FLX1(0,15,1), 0.0, -1, 0, 0.005, 0, 0, 0 ! "F" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,16,1), 0.0, -2, 0, 2, 0, 0, -1
*SET,HEAT_FLX1(0,17,1), 0.0, -4, 0, 1, -1, 17, -2
*SET,HEAT_FLX1(0,18,1), 0.0, -1, 0, 1, -3, 4, -4
*SET,HEAT_FLX1(0,19,1), 0.0, -1, 7, 1, -1, 0, 0
*SET,HEAT_FLX1(0,20,1), 0.0, -2, 0, 6e7, 0, 0, -1 ! "A" goes here 4te Zahl von Rechts
*SET,HEAT_FLX1(0,21,1), 0.0, -3, 0, 1, -2, 3, -1
*SET,HEAT_FLX1(0,22,1), 0.0, 99, 0, 1, -3, 0, 0
! End of equation: Q(x,y,t)=A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F^2)
sf,a1,hflux,%HEAT_FLX1% ! Replace FACENAME with a named selection
Da ich leider noch nichts mit APDL machen musste und keine Erfahrung habe, könnte mir bitte jemand erklären, was dieser Code macht, damit ich es auf meinen Fall anpassen kann?
Denn wenn ich das einfüge, passiert gar nichts.
Ich würde mich sehr über Hilfe freuen
